Trying to build a tow boogie with a rudder so we can get it back easily.
Using the VESC 75V 300A, along with the “Maytech Electric Longboard Esk8 Remote 2.4GHZ MTSKR1905WF” that has 2 tigger buttons. We only use the main trigger for the motor, and wanted to use the break trigger to control a servo that would be attached to the rudder.
when contacting Trampa boards about the VESC they said it is not possible because it would require too much current.
when contacting Maytech about the remote, to have the 2nd button control a whole different board/power supply, they said they could program it do that, BUT I would have to buy 200 remotes from them to have them do it.
Any ideas on how to get that other switch on the remote to work with a servo?
