hello
I am looking for help to operate my 65161 motor, I have just connected it to my new VESC TRAMPA 75/300, the detection went well but when I accelerate with my VX3 remote control nothing happens
[I’ll try that right away, thanks
In the VX3 settings, select FSESC
Did you get some values from the VESC in the Display from the VX3?
And when you pull the trigger, the yellow scale moves to the bottom of the screen?
yes, when I press the trigger the yellow bar moves
And the blue LED is lit constantly on the Bluetooth module?
yes, the blue led is permanently on
And the connection of the module to the esc is made with standard wires with connectors, or did you cut them off?
Do you connect the Receiver with the PPM or only the UART PINs?
I am connected with UART wires
I found, changed the type of control, I switched to current instead of "off"163226|690x264](upload://xFdcUY8v6YHn4zkUcx76SSQAhUN.png)
Hello,
I see that you get bat. Info on the vx3 remote. Is it bat. Info from the foil battery? Because i am not able to get it in screen of my vx3.
you are well connected in UART ?
Hello,
yes with uart. But i am not sure if my settings in the wizzard tool is wel done. But somehow i am able to see the vesc temp. In my remote on the display. So rx and tx are connected wel. But bat. Status is not displayed.
Are you able to help me with this?
The cable connection is like this:
