I have been getting final parts together and am in need of some advice before taking a wrong turn on motor position to the mast to allow for the most appropriate prop diameter.
I see a lot of people are stearing clear of the flipsky prop (i have bought one with the motor) and opting for a smaller diameter prop. Should I fit the motor high enough to enable the larger 7 1/4 prop or equivilant options or drop it closer to the foil for a smaller alternative?
So far I have bought the following;
120kv 65161 motor
flipsky 75200 esc
flipskyvx3 remote
gong foil
200A smart ant bms
I was looking to build a battery from 21700 Molycel P42A. initially looking at 13s10p configuration. Is this sufficient?
Board wise I was looking to build a board from EPS over the next few weeks.
Any advice on the above would be greatly recieved and any pointers or links that may help me avoid too many costly mistakes
Thanks Chris
