Hey guys,
Can someone post his VESC setting running the FR motor FOC? I’m using the MakerX 75200.
I had no issue by the past getting the flipsky 120kv to run with the flipsky 200A vesc.
With the FR and 75200 vesc, I can’t get past 41% duty cycle under load (maxing arround 60A). If I get the motor to start spining out of water then drop it in I get 95% duty cycle 106A. It seems the motor for some reason can’t get to higher current underload.
I ran the large inruner wizard, use current control, no reverse. Max current set at 160A, battery max current at 250A. ERPM 65000
Free spining motor get up to to 7350rpm at 56.5v so it is bang on 130kv.
I tired to disable decoupling, no change
If I calculate the flux linkage based on 130kv it doesn’t match the value in vesc tool, it should be more like 5.3mWb
Uploading: 20210926_135819.jpg…
Processing: 20210926_135759.jpg…
Processing: 20210926_135741.jpg…
Processing: 20210926_135735.jpg…
Processing: 20210926_135729.jpg…
Processing: 20210926_135724.jpg…
Processing: 20210926_135717.jpg…
Processing: 20210926_135712.jpg…
Processing: 20210926_135654.jpg…
