So I just got my batteries, esc, and motor hooked up. I set up the motor using the VESC tool, and everything was looking good. Then, the tool said I had to update my firmware if I wanted to set up an input. I went to firmware, and the only option was 75_300_R2, so I used it. Then I reran the motor config, and now my motor jitters and heats up instead of turning smoothly. My motor is the flipsky 65161 and my esc is the flipsky 75200. I bought them together here.
Can anyone give me any advice? I don’t know what to do now. Is there a way to reset the firmware on my esc so I can at least determine what component is causing the issue?
Edit: I can post a video of the motor if it would be any use.
