Hi.
I’ve ordered a Flipsky FSESC75200 with watercooling enclosure. Regarding watercooling:
The ESC has two water intake ports, and two water outflow ports. Will I have to use both circuits to effectively watercool, or can I just use one? Four hoses seems like a lot to try and cram into the mast.
I’m planning to run one intake hose up to the nose of the motor clamp assembly so it draws in water passively while moving through the water… but where should the outflow be routed? Maybe run it out a hole in the bottom of the motor tube just in front of the propeller duct?
Thanks!
