If I am not running my cabling through the mast like I have seen pics of here. How would one run the 3 phase cabling from the back of the motor to the mast?
Hello @tkramer I’m finishing my project with the same motor. see here.
Foil Assist with Flipsky 65111 for Axis Mast (and Flipsky 75100 ESC)
I’m thinking the same than you. After assembling the wholething and going into the water, realised how troublesome is to put tape every time, not only around the motor but around the mast and all the way onto the board. This week I’ll design some 3d-print that will go from the motor to the nacelle and into the mast. such that not only makes it aerodynamic, but also eases the assembly.
Hey, do you have the files for that print for any chance?
