How did you get it so round?
it is the center of the original propeller. (I had two) I adjusted it on a lathe and now it will be attached by welding.
Very nice build. This is exactly what I had in mind. Good to see others who know how to properly use LiPo batteries without causing fire. This is a clean build!
Thank you for the praise☺️
Would it make sense design the shark fins on the hub already with cw/ccw (depending on prop) shape? The water get already guided in the desired rotation…is it stupid? Am I stupid?
I want to see the first dual motor setup. One CCW, other CW, this is just a RC plane with extra steps(waterproofing)
You really want answers to your last question?
LOL that is great. 20 char limit
Hello Zaja,
Can you please share with us your Mast Clamp STL files?
Thanks,
Eran
I can’t put it here, send me your email, I’ll send it to you there.
Thank you for the battery info. Tattu batteries was a new company for me. Do you ride with two batteries? And in series? What is the ridetime with two batteries?
Yes, I ride 2 at the same time, a total of 50V and 22Ah. The operating time depends on the rider’s weight, I ride with 93 kg for about 30 minutes and my wife with 50 kg rides for over 45 minutes. But the batteries are older (I bought a used one from a drone) and the capacity will no longer be 22, but I estimate around 17 Ah.
How did the cut down suzuki propeller worked compared to the previous one, thanks?
I’m sorry, but I haven’t had time to try it yet. I will try in the spring☺️
OK, thanks anyway, will be interesting to see the result, little more pitch. Not that long time to spring now
Nice. How do you do the cooling of the ESC with that water line?
