Foil Drive Assist, DIY
slow progression. I might need more red, as red color enable better pumping!
Did you have any luck with the 65111 motor. I ended up choosing this motor since I was hoping to get something in between a 6384 and 65161 but feel like I might of made a mistake since I can’t really get enough power without pushing the current pretty high. I feel like I would have to run the current at like 120A if I wanted to get up and foiling. I appreciate any help.
progressing.
Did you find out if they are spaced the same Tim? I am thinking about getting some aluminium props and a hub and it would be great to know for sure.
Is it only for the ESC and/or the remote receiver ala Elevate ? The introduction of the FlyColor ESC’s in our DiY niche allows new possibilities. Adjusting the size of your device to the mast plate footprint exacltly means decreasing its possibilities though …
They are the same mate.
I have a FD hub fitted to a cheap BDUAV 6384
Great news. Thanks a lot for letting me know.
Just ordered the three blade. I will let you know if it fits.
Great. Thanks Tim. That is the route I want to take. If the two blade fits, the 3 blade will too.
I have way more space than needed and like the very integrated footprint.
I use mini FESC 6.7 PRO from flipsky, working very well for my light weight (65kg) with big front wing (1400-1900) but very small board (17L), still have to test it with smaller wing, but ESC temperature stays below 60-65 degrees after 5-10 min efoiling (with external ALU heatskink)
I have to test it with bigger guys also, but for me it’s a good ESC for a foil drive assist
Got a pic of the heatsink?
https://fr.aliexpress.com/item/1005003432486308.htm
l
I have that same vesc but it overheats in 13sec even at 40a. What does the custom heatsink look like?
I read somwhere that the mini 6.7 from makerbase is not good, only the flipsky
I have the Flipsky version…
I noticed the HiBox is an extremely tight fit for the FD+ prebuilt battery I have. So I switched to a CamdenBoss box which is about 5mm higher. Now I‘m wondering how you guys remove all the spacers and fixing points inside the box. Did anyone try using a desktop CNC machine? What bits and CNC parameters did you use?
I could of course just use a Dremel but the results aren’t very clean as the ABS tends to melt and smear.
I used a CNC mill but just jogged it along slowly. You should be able to do 6mm bit, 2mm DOC and around 1000mm/min depending on how strong and fast your spindle is.
Whilst sharpening a chisel I found the heat generated allowed it to slice through the plastic like a hot knife through butter.
This was a pelican case though and access may not be possible for all the little studs on the hibox
Hey Nicolas, do you have a link for that heatsink? It can’t be flat on the backside based on the shape of the FSESC 6.7. How did you solve that problem?
