3D-printed folding propeller
Hi, Austin, this will be very helpful.
What kind of engine do you have available?
Tested my folding prop yesterday. Main idea to use it on flat water was to reduce drug and board “diving” when you release the trigger. I did not notice big difference between folding and regular prop. Maybe it is just me, i do not have surfing and pumping experience. @Toto44 was right 160mm size seems overloading my motor. You can see it on log(GPS did not work properly). First 12 minutes was on folding prop trying it “on and off”.
Then i put my favorite 145/0.5/0.9 Cruising speed was 20-22km/h (recorded by Garmin watch), 3950-4000 rpm, 42A.
api.wavrx.com/f2
If somebody wants to play with this folding prop here STL files. Reason i printed blades on “side” to prevent delamination around axis of rotation. Model was done on https://www.wageningen-b-series-propeller.com/ with parameters:
Diameter 160 mm
Expanded area 0.3
Pitch/Diameter 0.9
Rake 15
Hub:
Upstream D 63 mm
Downstream D 55 mm
Length 40 mm
Blade:
Root 7mm
Tip: 2mm
Leading/trailing edge fraction 0.15
Printed with PLA+ , 80% infill, ZigZag, support > 75 degrees
Always print my props with such parameters (10-12 total). Never had broken one.
Link to STL files:
@Dynamik,
I’m looking to implement the Flipsky 65161 120kv.
It also has a lot to do with the wings you use. You need high aspect ratio wing, they have less induced drag and will keep gliding once you power off. You also have to shift your weight on the back when you release power
I see. I suspected it. I have a Cabrinha Varial Medium wing 1300cm. It has AR=4.6 witch is not very high. I noticed it has a lot of lift, hard to hold it down on speeds higher than 20 km/h. What foil would you recommend for higher speeds?
The high aspect 10:1 wings like the Axis 999 are very power efficient and generate lift from low speeds.
An higher aspect wing will generate more lift for the same surface than a medium aspect so if you already have too much lift with the 1300cm aim for something arround 900-1000 as suggested by Jatem. Best to try
thank you Dynamik, yes it’s a good idea too, then you have to glue but you have to find a good glue, do you have an idea for the glue!
If you don’t do the first step (using a press to extrude the grooved brass sleeve), it’s premature to talk about a suitable adhesive. You may not even need to use glue if you use the same method to mount the propeller, which can be understood here True Glide Propeller | Fliteboard™ Australia . In other words, it will depend on how you use the v1 propeller, what material it is, the shape of the hub, etc.
Best would be to take the rubber hub out, get a part turned from aluminium, tig weld it, re face and balance. Glue usually don’t last long. On aluminium JB weld pretty good otherwise an industrial epoxy glue.
Thanks to a good samaritan, and the power of CC, the models are back up on Thingiverse.
Would be interesting to experiment around it!
I’ve printed a set of the props in SLS nylon.
Nice smooth finish.
Cost $15 per prop with a commercial printer.
SLS would indeed be great for making those blades, as otherwise, the presence of supports typically means that the surface finish is rough and needs epoxying/sanding or some kind of time consuming treatment.
Being small parts makes it affordable to get them made by professional outfits, while the chunky hub itself can be printed at home in less refined material
Why not rotate the blade and print standing?
what about making a negative mold in epoxy resin/fiber glass and make the propellers out of carbon?
You’re right, I assumed that the print would be stronger like that, and weaker along the Z axis, but that’s just an assumption, and I’m not at any testing stage to see if there’s any truth to it or not. Not even sure I’d end up with this type of prop. Just printed one in PLA+ for now, for tinkering purposes.
And there’s plenty of wind and waves at the moment for some good old fashioned foiling to delay whatever side project I have in mind.
Just an idea of mixed technology folding propeller. As 1-3d printed folding blades tend to break easily 2-since CNC time is costly and 3- it is easier to mold two or three small alu parts rather than a big prop…
@jeffM, do you think you could mold a pair of small foldable quality prop blades with your aluminium casting process ? I have moulded blades in mind mounted on a 3D printed hub, if it can resist to repeated ‘violent’ blade openings. If not the hub could also be moulded in aluminium. Then comes the delicate step of balancing.
Pict credit to @Foil_A_Lot
If the violent blade opening is causing failure, could we add a pad of damping material to soften the blade opening, much like the Flexo-drive folding boat propellors use?
I haven’t seen much information on whether people have tested non-brittle filaments for the folding blades such as nylon+glass, or even PLA-ST (which has much higher impact toughness than PLA/PLA+ which are both known to be very brittle).
My assumption. Worth a try and easy to implement … especially if boats are already using this to dampen the opening shock impact supposedly detrimental to folding blade life duration.
