Is the motor treated and waterproofed? Sounds like it might be getting some water somewhere.
Is it working normally out of the water?
Timing degrees at atleast 25? No low voltage cut off?
Yes it is but no I didnt coat the wires
Yes timing at 24 degrees
Tried both props 3d printed and aluminim
I think the water is shorting the phase wires somewhere. As soon as there is enough power it’s shorting. You need to make sure the wires are waterproofed properly.
I have been waiting for this post
How good does this work?
Well I hadn’t the chance to try it yet. In 2 weeks I can tell you more after I’m back from my holidays.
Great can you show the cad files and how much filament did you use? And file type: .step
I can share the files after I’m back home. You will need about 200g for the prop (PLA). The other parts are printed in PETG. Don’t try to print the clamp in PLA if you want to have a longer lasting pod.
Riding on sea swell is sooo much fun!
and did you test it?
Looks sick is the 80100 still in the water or is the motor running dry. If so isn’t it overheating?
The motor is in the water. The design has some openings for a small water flow.
great location. can zou tell me then the loss of the duct and how efficent it is without?. and im a bit worried about cooling.
