A build with a feminine touch?
To get started, I printed the motor mast clamp, just because it seemed like something I could do.
Following the method used by YAHEF, I adapted the design to my mast and motor using fusion 360, and to make a long story short, ended up printing it in PETG with 100% fill.
QUESTION: has anybody used a PETG mast clamp without any additional processing (fiberglassing, epoxy filling, etc…)? I just reinforced mine with a couple of heavy duty (200lb) tie wraps around the circumference…
EDIT: after reading here about improving the strength of the print, i might reprint the clamp with:
  • PETG
  • layer height: 0.15mm
  • layer width: 0.56 mm (140% of nozzle width)
  • perimeters, top and base layers: 10
  • infill: 100% honeycomb (don’t know if patterns matters at that point)
Not taking any chances!
