So people, now it’s getting serious. We have actually landed far below 2000€.
For all those who want to build an Efoil now should use these components (as of January 2021).
Quiet motor, high quality battery pack (waterproof), passively cooled VESC (waterproof). High quality carbon Foil.
It took us less than one day (23h) to build everything!
| BOM | |||
| shipping | |||
| Flipsky 65161 120KV | banggood.com | 269,00 € | 8,00 € |
| VESC HI200 75V 200A | hgltech.com (coupon HGLTECH20) | 161,00 € | 10,00 € |
| RL Foil Set (Shark) | rlboards.com | 420,00 € | 15,00 € |
| Battery 16S9P 30Q | nkon.nl | 460,00 € | 10,00 € |
| Maytech Eskate remote | aliexpress.com (MTSKR2005WF) | 80,00 € | 20,00 € |
| Max case 004 | max-koffer.de | 24,00 € | 5,00 € |
| Nuprol X-Large Hard Case | kotte-zeller.de | 120,00 € | 12,00 € |
| stiffer plate | Local Laser shop | 53,00 € | 0,00 € |
| Item profile 30x30 | ebay.de | 20,00 € | 6,00 € |
| aluminium case 172 x 121 x 54.9 | voelkner.de | 16,00 € | 5,00 € |
| stuff | AS150 connectors, 8 AWG cables, screws, SikaFlex | 50,00 € | 0,00 € |
| 1.673,00 € | 91,00 € | ||
| 1.764,00 € | |||
| working hours | |||
| [h] | |||
| propulsion unit | motor mount, cut POM piece, assembly of foil | 5 | |
| battery | spot welding, soldering, prepare waterproof hard case | 7 | |
| board assembly | screw stiffer plate to board, seal screw holes, install rivet nuts | 6 | |
| VESC box | soldering, install cable glands, programming | 4 | |
| remote | waterproofing remote with Epoxy | 1 | |
| 23 hours |
