Hi, latency looks much better now - has anyone tried it?
@qdbluemind
When switching to cruise mode: does it save last speed setting?
When in cruise mode, how does the throttle behave? On/off?
Will all available remotes at Alibaba be newest version?
@brycej
How about deactivating the onboard antenna and connecting one with cable?
@DanDyse @soriginal
When switching to cruise mode: It will save last speed setting.
When in cruise mode, the throttle is off.
Will all available remotes at Alibaba be newest version. yes ,it is available.
The Bluetooth pcb has been redesigned, and an external antenna can be connected。
I also have one, looks promising, GPS and trigger works fine (altough a little bit laggy), however it doesn’t read data from VESC (tested with Flipsky 75100) and I have the old receiver which doesn’t have an external antenna which makes the board impossible to start.
@qdbluemind Can you help to set up communication with the VESC? Is it possible to purchase the new design receciver with external antenna connection from you? Or if you can send a binary I can upload it to an nRF52 board with external antenna.
I also managed to read data from the 75100 as well, maybe it was hardware related as after carefully checking the connectors I realized that the TX pin on the VESC was misplaced a little bit, so my bad, sorry
I sent you my email address by PM
Anyway can you share more info about the VESC you’re developing?
Great! Do you have plans about price and date of availability?
Anyway can you send me the receiver firmware to telandras@gmail.com? I sent you a PM, but maybe it doesn’t work
Andrew
We are going to carry out some customer feedback activities and give some discounts to our friends. The remote control will be sold at a discount of 5% between 9.21-10.21. There is also a group purchase activity. You can buy three at a time and enjoy a 10% discount. You can buy several with your friends directly and enjoy a 15% discount. We can send them to you and your friends by multiple express deliveries. Let’s feel the charm of surfing with your friends!
The link is below, click get samples to buy!
Hi, can you help me? I tried two way to connect the board to the vesc,but i can’t remote to the motor.
I tried pwm and UART port .my board might be broken? there is a smd led on the boart and it’s pale light. but if connect mattery to the boart i can see the voltage on the remote and also connect bluetooht with the board.can you help me what sould i do? or can i buy another board?
Just curious to know if forum members have bought and tested the August 2022 remote release with corrected response time and 10Hz screen refreshing rate.
