Hi guys! It’s my firts post, after reading hundreds of yours!
I’ve started my build and want to share the process with you, and also help others who will learn from my process.
I am buiding my first Efoil. I read a lot in the past weeks. Everything I know at this time comes from you guys!
Board:
It will be 120cm long, built from scratch in XSP foam and fiberglass.
I will build an waterproof enclosure inside the board for the electronics.
Didn’t start this build yet.
Mast and Foil
I’ve bought a used F-One kit, one mast, rear wing and 2 front wings (1280cm2 and 1800cm2)
The mast is 75cm : Alu Masts - F-ONE
Does somebody have a 3D printing model for a motor holding bracket for this mast and a flipsky 65161 Motor?
(I dont have a 3D printer, I will ask a friend)
Battery
I have ordered 140 x Molicel 21700 P42A 4200mAh 45A
I think of doing a 14S10P setup
I searched and could not find a perfect 14S10P setup that I could imitate. It is my first battery build so I would want to follow a model.
Right now Im thinking of going like this one : https://voltaplex.com/14s10p-50.4v-28.8ah-li-ion-18650-battery-pack-panasonic-pf-cuboid
In this model, I would need 2P nickel strips. But I see a lot of build that use a single strip on every parallel cells row. I’m lost a bit there.
I am looking at these : https://aliexpress.com/item/1005005548167194.html?spm=a2g0o.cart.0.0.7678378dshGRKz&mp=1&gatewayAdapt=glo2fra
It is made by SUNKKO, and looks to be really Pure Nickel Strip. I am thinking going 0.15mm?
Or should I go 0.20mm in nickel plated strips ?
BMS : I think it is safer to have one ? I think it is simpler to use it to charge and discharge ?
A famous one here is the Daly from alixpress : https://fr.aliexpress.com/item/1005006413689266.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.1.23f43170aQ5r7t&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=99f8227e-2b1e-49b5-bedf-82c35970e9d1&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:99f8227e-2b1e-49b5-bedf-82c35970e9d1,tpp_buckets:668%232846%238108%231977&pdp_npi=4%40dis!CAD!19.92!13.15!!!14.39!9.50!%4021032e4e17120108583173192eb5e7!12000037095883027!rec!CA!860052467!&utparam-url=scene%3ApcDetailTopMoreOtherSeller|query_from%3A
I need a 14s 48V… and how many Continuous Discharge Current amps ? 150? considering getting on plane with my 65161 Motor and my 75kg, will take 90-100Amps ?
Do you have a better option?
Any recommendation for a charger?
Motor and ESC
I ordered the famous flipsky W7 group : Group W7 Water Sports Kit (Includes High Current FSESC75300 /75200 and – FLIPSKY
65161 Motor 12MM ROUND WITH THREAD/NEW
120KV/With VX3 Remote
75200 With Water Cooling Enclosure
I will keep you updated!
Thanks in advance, I am learning so much from you guys!
