Hello Ludwig,
As far as I understand the V2 will only fit dual motor tow boogie for a differential steering?
The capacity of the RX is not enough to supply power to move a strong servo and there is no other solution to do it. Right ?
Tks for the input
You can just buy a high current BEC and connect to the BEC1 input of Rx
Then connect servo to ESC1 output of Rx. Done.
Hi all,
I’ve had the honor to start beta testing the new jewel from Ludwig. In a nutshell, the BRemote v2 is just nuts. You can immediately see how much effort, dedication and likely time with so much attention to details he has put into this. I have been using the Bremote v1 and own two of them for more than a year.
The ergonomics are very good and it’s designed to be customizable. Yes, you’ll be able to design an adapt your own handles. This is definitely a game changer vs v1. The precision of steering is also super comfortable.The trigger is reacting perfectly and it’s also very “repairable” if you need.
The print quality is also impressive, it’s silky smooth when you hold it. PLA +.
The remote weights 208 grams mainly because of the li ion battery and also a different kind of gel that replace the PU foam.
The receiver comes in stack of two PCBs and decided to make it flat for my setup and put it in a 3D printed box filled in with MagicGel.
The signal transmission is VERY good, almost impressive.Even under the water surface in non salty water.
The remote has a very simple and straight to the point LCD that gives you the voltage and the signal link.
The v2 already include a BEC, so no need for the ones like me that use Flycolor/drone ESCs.
I’ll keep updating you as I ride it more and more but a big round of applause for Ludwig. Game changer.
a video riding the Bremote v2 okp on Instagram: "two hearts."
and few photos!
Is the MagicGel your own modification or is that the intended potting for the V2?
I always host my electronics ESC, RX in simple 3D printed boxes and put MagicGel. So it’s a personal take :wink:
Nice, I like the idea of it being removable and soft. I’m about to pour some in my esc box on my almost completed project
yes, the stack option is great but I wanted a more flat setup to fit my existing box replacing the v1 RX.
The honor is on my side, having such a talented foiler test the remote :wink:
So here a short update on the V2:
As you can see, the first beta units have been sent to the testers and are in use as we speak. Thanks to the detailed feedback I could already make some more improvements to the code and get a good feeling for the maturity of hardware and overall design.
I have also compiled a short clip, showcasing the first 2 uses of the remote:
  1. A professional foil teacher located in the north of Germany. His main use case is to control a tow boogie from land over long distances, in order to teach his students. His favorite points were the very fine steering as well as long and stable connection.
  2. The one and only OKP himself. In his boogie, the remote controls 2x “classical” ESC. Check out his post above for all details.
My short video can be found here:
Next steps:
I am currently planning the kits together with Jasmin from openfoil as well as preparing all the files for the remote and instructions for assembly and configuration. Jasmin will post details on how and when to pre-order soon.
I will also prepare more beta kits as soon as I can find the time and contact the next beta testers as soon as possible.
GPS works
I have released the project to github!
Thank you to everyone contributing in this post!
All project-related questions can now be put under the new topic:
With the V2 released, I had some time to work on the Nano version
See the update here:
Also for this version, a few beta testers were selected and I will contact them soon.
I had some “crazy” ideas that I wanted to test out for the remote as I personally didn’t love the exposed trigger so I just made a little “prototype” that I would want to try and also see how it fits irl.
ps. this is just a rough draft of my idea how it could look, would love input from you all :slight_smile:
Looks interesting
Just make sure not to use any metal hardware around the top front edge of the remote for maximum range (that’s where the antenna sits)
I believe that @rttn made a pistol grip handle already.
Here’s my opinion: this is completely unusable. There is no room for the index finger, let alone the finger in gloves. There is no point in covering the entire hand, you only need to cover the trigger. If you use an M-16 style grip, then look at the Magpul trigger guard - it is a model of excellent ergonomics.
Oh thats nice might steal his design then :slight_smile:
I like this version much more. And it is definitely safer and more ergonomic. I think I will wait for the release and buy it.
Well the reason for this design is for three reasons:
  1. So you can plant your hand with the remote when preparing to stand up.
  2. So it has 0 resemblance to an actual pistol.
  3. To guard the trigger.
This was just a rough draft of how it might look and I will print everything and see how I will adjust it when I have the base model in hand :slight_smile:
I second that if I haven’t ordered the other model already I might’ve gone with the nano aswell :rofl:
I’ve been thinking of a design works one-handed for tow boogie. You see people holding the remote and rope in one hand, it is quite awkward.
I think there is a place for the remote to stow into the tow handle, and then you pop it out when you drop the rope.
I made something like the below for tow boogie out of angle iron, it worked well, but extremely crude. Pushes the brake and engages cruise control so I don’t recommend, but as a POC it is pretty good.
Something to add to the mix of rough draft ideas :smiley:
