I break fuselages for free! Come, who is not sorry!
My mistake is that I cut the corner of the mast to enter the water to cool the esc. This weakened the attachment to the fuselage.But I’ve been riding for two months!
I am sure the next fuselage it will be stronger
Why not use the clamp for water intake?
You won’t believe it, but I fixed it!
I will cut the bottom of the mast by 10mm.And I will make the entrance for the water higher!
Of course you can! But I did it under a self-made fuselage without a milled well! There’s no problem with him! And with a purchased fuselage with a well there is!
My new dry wetsuit for cold weather in the color of autumn!
The water is 8 degrees! It’s almost Summer! Let’s ride for now!
Damm here in Mallorca it’s 18º and for me it’s really cold
Yes, I would also like to ride in Mauritius in just shorts right now! But I have to wear three wetsuits here! And the battery will not be transported by plane!
You can push the motor now to 10kw; overheating might be not an issue
Trio! The season continues!
Again, I wound someone’s spinning on the screw!
