Corrosionx Flipsky 65122 + 65161
hi all,
question from a newbe
do you fill the motor with oil fully and close it again
or fill it, drain it back out and then close again?
@janefoil
The 65161 is a “waterproof” design so in theory doesn’t need this. Some people choose to open it up as a preventive maintenance others don’t.
There are multiple threads about the maintenance process found by using the search function.:grinning:
Like this one
EDIT Forgot I had to use quote characters to get link to work
END EDIT
‘65161 maintenance
There are pro’s and cons…
If you fill with CorossionX, then it will degrade the silicone wires over time and you will then need to replace the wires. (I have this on my motor)
Mineral oil is a better option, but I would fill, let it coat and then empty and do this periodically…
This is how we do it too.
