impressive printing quality mate! what printer are you using?
@okp: Full modded Vyper
Once upon a time there was an Anycubic Vyper. Everything was replaced except the frame.
How do you get those beautiful textured faces on your receiver/batt display? I’m assuming it’s the type/brand of platen?
It’s a 3d printer pei plate
Awesome design , pls share the pod file for axis alu on step or f3d file format . I would like to play around with this format . Thanks hips
Thx.
Sorry, I never give out STEP or f3d files.
?why? I always share my steps no publicly but privately
Hello, which charger did you use?[quote=“lishine, post:73, topic:19307”]
Junsi iCharger X12
The cables are finished with the MTW-60 connectors.
Everything soldered and filled with epoxy.
First setup, 6384 with FoldProp gives my pump setup. POD to approx. 30-10cm.
Second setup for pure efoil operation with HyperDrive for the 6384.
Third setup, sometime in 63100
with HyperDrive. ![]()
I like the zip ties on the mast trailing edge (*). The set looks ready/mature for mass production ![]()
(*): wonder if there couldn’t be a sharp fairing on the trailing edge to close a proper streamlined profile up attached with the same zip tie.
Good morning
where can I find the 18650 battery holders? Thanks again
It‘s a 21700 Battery Holder.
I don’t have the battery holder online yet.
Very nice setup, congrats !
Do you use maytech waterproofed 6384 kit ?
No. 6384 BDUAV and filled with epoxy and stainless parts.
@vib.dxb: STEP Files now included at my printables!
https://www.printables.com/de/model/620724-slingshot-hoverglide-motorpod-for-6384-and-axis-un
Glad you saw the light of jesus and he guided you to upload the step files
Super cool design. Thank you for sharing! I finally got to building the connectors for my tow boogies. It is really going to improve the safety and will look a lot better! This is the new design for the top plate for the motor mounts.
Yeah. Very cool.
Good Idea with the connection mount ![]()
