Hi everyone!
After spending countless hours reading build logs here, I finally decided it’s time to share my own project.
This is my first DIY eFoil, and instead of buying a complete kit, I wanted to build as much as possible myself. The goal wasn’t just to save money—it was to understand every single part of the system and learn along the way.
This thread will document the entire build from start to finish.
So far I’ve already completed (or nearly completed) most of the major components, and I’ll be posting the whole journey with lots of photos and technical details.
Here’s what you can expect:
Choosing and buying all the components
Designing the board in CAD
CNC cutting the EPS foam core
Laminating multiple layers of fiberglass and carbon fiber
Designing and building my own front wing
Building a custom 15S16P battery pack (BEAST!)
Installing the BMS and waterproof electrical system
VESC configuration and tuning
Bench testing the motor and battery before the first ride- (Hopefully…) successful water testing
Project Specs
Board
- Custom CNC-cut EPS core
- Carbon fiber + fiberglass composite construction
- Approx. 168 cm × 60 cm
- Custom designed from scratch
Battery
- 15S16P
- LG M50LT 21700 cells
- Around 80 Ah capacity
- JK Smart BMS with active balancing
Electronics
- Flipsky FSESC 75200 Pro V2
- Flipsky VX3 Pro remote
- Flipsky 65161 120KV motor
Propulsion
- Folding propeller
- Custom waterproof wiring and connectors
One thing I wanted from the beginning was reliability.
I know many DIY projects focus on making the lightest or cheapest possible board, but my priority has always been building something robust that I can trust on the water.
That meant spending a lot of time thinking about waterproofing, battery safety, connector reliability, cooling, and serviceability—not just performance.
I’m sure I’ve made mistakes already (and probably many more are coming
), so I really appreciate any suggestions, criticism, or ideas from experienced builders.
I’ll keep updating this thread as I organize the photos from each stage of the build.
Next posts will cover:
- CAD design
- CNC machining
- Lamination process
- Wing manufacturing
- Battery build
- Electronics installation
- VESC setup
- Bench tests
- First ride
Hopefully this build log will also help someone else who’s thinking about building their own eFoil.
Thanks for reading, and let’s see if this thing actually flies! ![]()
