Hi, Please do you have these model in STP ? I have a different section mast and i can’t use this STL files.
Valentin
No sorry for the clamp, I have only the STL files.
The mast clamp files is the Rober’s creation, you can ask to him (nice2cu)
Thanks a lot but these files are also in STL
Ok thanks, I will contact him !
If you can’t find the vertical Relay model in stock in Europe, try the “side mount” part no: 4-1618391-2 model: LEV100A6ANH
See below I have already installed it on my V4
it’s more simple with this relay
I know @jeffM.
I just posted it here for others to see, because I have been looking for it for 2 days now…
I finally thought of searching for the horizontal model
Hello @jeffM,
I would like to ask for a favour, if you can.
I need the dimensions and the hole positions of the Gong connecting plate, because I am at this stage on my board and my foil is still in the mail…
If it’s not too much trouble for you, or anybody else I would really appreciate it.
Thanks!!
I have these dimensions,
but I have a doubt about 88.9 it seems to me that it is a little more (90mm ?)
Thanks @JeffM for the quick response!
It will do for now, at least until I get my foil.
I will wait for you in Crete, so we go foiling together…
This should help. Beware that there is a new mast plate since 2020 (plain no fancy hole).
'Database for mast & plate - #84 by Ivryl
@jeffM, Any chance you can post the original 3d files (not .stl) for Gong, Flipsky and alu esc box ?
Thanks again!
I have a step for gong, but you’ll have to dm me so I can email it to you.
Morning JeffM.
Fantastic job you are doing and thanks for taking the time to share with everyone.
Your original 23A prop I think you called it. What RPM where you spinning it at. With the 5” pitch I am looking to spin mine around 4000 RPM to start off with.
Hello! I tried contacting you by pm, I would be so happy if you could share the step files for the gong-flipsky clamp system?
Thank you in advance
Hi, @Fabien_n the mast clamp I’ve got works the same way as FR’s one and needs to be machined out of aluminum, I’m not sore it will be of much use to you? Printing it will not be strong enough unless you modify it a lot.
I actually need it because I want to try CNC’ing it in aluminium as well, and they need a step file and not a stl.
For the mast pod in STEP or STP format…
'Efoil V3 - STL files for Gong foil and Flipsky motor 12mm - Parts list - Schematics - #79 by jeffM
@nice2cu should have it. If you go the forced flow water cooling way, @f16model, @Ackermann, @jnobile, @wushbush might have the Gong + Flipsky version.
Is it necessary to install 8 bolts for this plate. What is diameters? Thanks in advance for your answer
