Erayfoil Remote: Unboxing and Review
It’s a flipsky 75200. I’ve tried, but the throttle input doesn’t show up in the VESC software. From the videos I’ve watched, the line should move when you pull the trigger to help you set the max and min values, but when I pull the trigger nothing changes in the software. In the mean time, I added that new battery+ line to the board. That added the battery status to the remote, but then the wire must have bridged with one of the other pins. There was a big spark and it charred the receiver. I’ll order another one and maybe the new board will work. It could have just been a problem with the original receiver board, so with a new one I’ll be able to rule that out.
Did you go into the menu of the erayfoil and pair it to the receiver? The manual details the steps, must power the vesc/receiver on after starting pairing on the remote.
I’m finding the battery voltage gauge isn’t helpful, because it’s still showing 2 bars when I only have 40V left on my 13s battery. My first session resulted in a swim back. I would prefer two bars to be around 44V, 1 bar 42V, similar to maytech.
I wish the remote would just show the actual battery voltage eg 45.5V on the screen, it’s the only thing I really want to see accurately and big on the screen. Any chance of a firmware update with this?
Remote is set to 13s and I’m using a Vbatt wire to read the voltage.
Any other experience of the batt gauge?
Try to set it to 14s, maybe then you get better result
The remote appears to be paired. The input shows up in the VESC when setting the min and max for the throttle. The white line moves in the software when I pull the trigger. Also the motor sort of tries to move when I pull the trigger. It makes little micro movements and sounds like it’s trying pretty hard to make the blades move but they won’t. The motor also gets pretty warm when it is trying. I would think that something is wrong with the motor but it spins fine when I run the motor detection wizard.
It seems that your remote is paired and working ok, and it could be a vesc config issue - have you tried a different remote? Are you running the vesc PPM app in duty cycle or current control mode? I have had issues with the motor not starting in duty cycle mode, but current control works well.
I would prefer that the included antenna was longer, so that I could run it outside my aluminium vesc enclosure. The maytech remote has a 1m antenna option you can include with the remote purchase.
I’ve tried both current and duty cycle and they seem about the same. Havent tried another remote but at least through the setup for the remote on the VESC the software seems to be responding accurately to the trigger pulls. I am thinking I might delete the PPM app and re-add it. I think that would wipe out any bad settings that might have been set without me realizing it.
Is it weird for the motor to get hot when I’m running it. The blades aren’t really spinning but the motor gets hot. I was thinking maybe that isn’t normal and the motor isn’t spinning because the controller sees that it is too hot.
Mike
I encountered an unexpected issue today where I couldn’t get onto the foil, caused by the erayfoil limiting max throttle. It turns out that when you hold down the - button for longer than the 3 seconds required to unlock the remote (after a fall), the erayfoil remote starts reducing the maximum throttle level of the remote.
It makes sense that you can change the max throttle level by using - and + when the remote is already unlocked, but I think that when you are holding the - button to unlock the remote it should not go onto have this secondary effect.
Another feature request - I’d like it to display the actual voltage on the display, rather than 5 bars - eg. 45.7 V.
Found the solution to this problem. I needed to turn off Phase Filtering. This thread was posted yesterday and had the solution in it: VESC Setup Help Please!. Just posting this in case someone has the same problem in the future and finds this thread.
The (-) button is taking increasing thumb force to unlock the remote. Is it possible for the safety lock feature to be disabled completely?
Is anyone else bothered by a large amount of thumb pressure required to unlock these remotes? I’ve bought three, and the last two are taking a very hard push of the “-” button to unlock the remote.
Edit:
I think I have found the problem. They aren’t calibrated from the factory, and the throttle is registering some movement at rest and therefore refuses to allow unlocking. After going into the remote menu and entering a min and max in the calibration section, it’s unlocking easily.
That would mean the “-” button is actuated in some sort or that there is an adjustable locking force.
This is surprising on one of the cheapest remote on the market where no other brand offers this.
It was probably just flexing the board, reducing the throttle signal. The issue was the calibration not being set by the factory, and it won’t unlock unless there’s no throttle at all.
I just tried my new erayfoil remote, had a hard time setting it up.
First it was locked no matter what i did, I couldn’t unlock it by holding “-” button as described in the instructions.
Tried pushing, holding every combination of buttons, finally i got it turned on straight into the setup menu where i could use the buttons.
To achieve this I had to turn it off and press + and power button (it’s not possible to get into menu from ”ON” state)
Then i did calibration of throttle and pairing.
The pairing was not straightforward, i tried a few times, even though it was shown saved as it should and remote showed connection on the display, however the pairing led did not turn on on the receiver.
Pairing was not completed until i started pairing in the remote program, powered on the VESC without the receiver connected, waited for some seconds, then plugged in the receiver - and finally got pairing LED to turn on. After this i could finally unlock and try it.
@Jatem:
It seems that you cannot unlock buttons until remote is calibrated and paired - which isn’t exactly clear in the instructions.
The pairing issues were probably caused by the startup sequence of the vesc so i don’t think that was an issue in the remote.
Once on the water the safety lock called “out of control protection” was not the best feature for my 110cm shortboard - i need to lie over the edge of the board to keep the nose down and easily got enough water splashed on the remote to activate protection and stop the motor - so i had the pleasure of doing a number of somersaults into zero degree water, then getting run into by my board…
@Franky @qzyf : I really wish that it was possible to turn off the splash safety lock feature in the program, it makes it harder to use the remote. Can you support with this option? I think i’ve seen more users having the same experience here on foil zone.
Also change all screws to stainless.
Mine were black anodized.
we plan to have the option to select the security lock in the new version
That’s great! Is the remote i already have possible to update?
When is the updated version available, with the option to disable the safety lock feature?
Unfortunately, these erayfoil remotes don’t seem to be waterproof long term. I can’t recommend using them in the ocean. After less than 12 months of use, my erayfoil remote has leaked water into the battery, causing a short on the positive terminal which drains the battery quickly. It is no longer safe to use.
Any news on this? I’m having too much issues with the overly sensitive safety lock feature, i wouldn’t recommend the remote to other users as it is now. When will it be updated?
