My build now continues. As I don’t like the concept with the 80100 motor I will switch to a waterproof flipsky 120kv inrunner with a flying rodeo prop. As I have enough time now to work calm on this project I think I will make everything safer and better. Currently we have -1 degrees and ice in the lake so I won’t be able to test it.
I decide also to build, next to my 63100 a mast/masclamp/duct configuration with an Flipky 65161.
So i can easy switch between my two systems.
I finish my hole work now in Fusion 360.
PErhaps you want use something from me?
Rebuilding the complete board. Ripped all components out and stated sanding. Unfortunately the paint is so viscous it always cloggs my sandpaper which makes it very annoying to sand.
