FlyTomaz - First build
It is dedicated PVC glue for boat repair.
… and done :grin:
It’s a little on a big side.
I already have a new idea for smaller board.
We were flying yesterday.
It takes in a little bit of water but was ok for testing.
really really nice, i hope to work fine
just to be sure, we can take an inflatable board like a gong hipe, cut it from the top, make room insert a carbon box and glue it in place with overlapping the top , is that this easy ?
Kind of :slight_smile:
What I would do different is:
  • making box smaller with custom hatch
  • start like you said with Hipe or similar board
  • cut the strands inside just far enough to keep the or put the box closer to the edge.
Also one option is to make half of the board solid and the other half inflatable.
Just an update: I decided to build another board…
I was looking at the case with all my parts and saw there is so much empty space…
My thoughts were if I’m making a portable efoil why not make it a case by itself (something like riffle case).
So this was the idea:
The build process in reverse (upload order):
Great idea, love the zip :grinning:.
How well does the zip and seal work? Any leakage?
Gaz
It’s perfect. Best decision ever. No leakage at all.
Just have to get use to small board.
Great to see some innovation. I assume you need to move all the electronics though to get the mast in?
where do you output the active cooling water ? I’ve only seen one tube in the mast
Second one is on top half. Second pic of build.
It is just one box and the battery which is caried separately.
Great idea Tomaž,
how did you glue the zip arround the board?
Great design: after the riffle case efoil, the Samsonite suitcase efoil :call_me_hand:
Is 5 minute epoxy. Before that it was put in place with twosided tape.
V2 is comming…
Anyone interested in V1 board?
Reusing V1 board and giving it a new hearth.
More on that soon…
I decided to use the board as is and add a home made jet with 66112 motor inside.
Battery will be the same and esc can handle 160A.
It is intended to be used as a toy for my 6y/o son or as emergency rescue vehicle.
Your son is going to enjoy that toy! What are the dimensions for the jet prop?
It is 65 diameter and 45 length.
It has 4 blades and pitch of 120mm.
Will see how it performs.
