Foil Drive Assist, DIY
@Strongarm @JFoiler I looked at the file but would be good to know for sure. Did you use a 4mm dowel/shear pin for the Pivot rod with a bit of glue? And the strap screw holes are 3mm, so did you use M3 or M4 caphead screws for that (M4 maybe to get a tighter hold)?
Capture2
