I love the spec on this esc on ali:
Which motor and kV do you use it with?
I can tell I am low on power 1st I have a power meter on my controller and 2nd I notice I have to use more throttle to get up onto foil. When I can no longer get up on foil—I call it quits. The voltage is 3.4v per call at this point. I use a 10s 3p or 10s6p setup depending if I am efoiling or using as a foil assist for wing foiling. I have a 6384 motor (120kv) with foldable prop and it provides plenty of power to get up 1800cm2 foil and 85kg. I can get up on foil easily until the very end ( individ batt voltage about 3.4v ) using a 10s setup.
I love these Flycolor dragon 80a esc that cost 32$usd. I spent about 700$ so far to find that the 30$ esc is the most reliable. Hahahaha
If you are going to put your money somewhere- put it on some good 21700 batteries, not on the vesc
Which prop are you using?
So, if it doesn’t have low voltage cut off, do you have to manually monitor voltage while riding?
I would like to warn you about the non-obvious danger when using Flycolor ESC. If you break and restore communication with the remote and you press the trigger at this moment, you can accidentally enter the programming mode. This happened to my friend - a break in communication, and then the board suddenly went in the opposite direction and did not react to the release of gas. It looked very dangerous.
thanks ! do you have a photo of your setup? 30 cells or 60 cells is quite a big box ? how agile is it ?
This might happen, but would have to be very unique situation. This is not unique to Flycolor. This could happen to all esc’s where , when initially connected and throttle is pulled and not let go , it may go into program mode. There would have to be exact timing here for this to happen. I have used esc’s for years and this has never happened. Not to say it cant.
This can happen to all non-vesc esc’s . It could happen to Hobbywing, seaking , seashark esc’s. I have all of these and they all operate the same way.
I am a promoter of the KISS principle. The vesc are not part of it. keep it simple stupid. Thats me, after a year of battling with vesc’s !!
i dont have a pict right now.
Small box is 5in (width) x 10in(length) x 5in (Height) 10s3p = Wing foiling box
Bigger box is 9in x 10in x 5in. 10s6p = Efoiling box
Here’s another example for you. Two ESCs that I used on the tow boogie. First, one controller went into programming mode, then the second. There is no documentation, an appeal to sellers on aliexpress with a request for documentation did not produce results. Replaced them with VESC 75200 and happy.
I printed about 6 props initially. 2 foldable ones worked really well. One was found on thingiverse
The other one was from this site, slightly smaller in size but a little more efficient. Can’t find it this minute
Did you have a go with the manufacturer, not only the sellers ?
This is the prop I am running…
Got a pic of this one, I’d be interested to see it.
On another very interesting note:
I will look for the other prop for you. Just no time right this moment.
I have not waterproofed mine at all other than ceramic bearing and sprayed with wd40. I have not gone in saltwater yet, but from what I have read, other people have not experienced leakage of power like you have?? I can get 100a easily when i push my motor briefly. I need 70-80 amps to get up, so i can see the frustration of not getting enough current to motor. Which ESC are you using?
Unfortunately, the manufacturer is unknown. FATJAY are sellers and they couldn’t or wouldn’t help me.
I assume that this ESC is one of the Flycolors, placed in a different case and filled with oil, because the first items in the programming menu are the same as the FLYCOLOR 150A
Guess there’s a diff in kV to explain the lower battery current, this would also need to be combined with a relatively big diff in efficiency to go together.
Slightly higher kV, less duty cycle for same rpm, more available voltage to create motor amps with.
But
Slightly higher kV requires higher motor amps to get same torque, less saturation of motor to get total torque.
KV out of the water is almost the same. It’s definitely a leakage current as I think I may have toasted my APD 120. I gave it full throttle and the separate HV bec blew up. Need to see if the APD survived. It was doing all sorts of strange stuff once it was in the water, but dry it was fine.
The arc200 can run it in the water with the leakage current though. I just need to dry it out and seal out the wires properly, then re-test.
I can see that, had an 80100 motor with leakage currents that stopped an esc for me. The sensorless measurement and control gets affected, then something blows if used further.
Which remote do you use with the APD? Any troubles hooking it up?
The maytech one. Setup was super easy.
I put up a couple more models in Thingiverse. I saw that Foil Drive added latch covers to the kit to prevent the leash from popping the latch open, so I drew a couple up for short and tall boxes.
Also made a little box to put the Maytech remote RX in for a little extra splash protection.
Finally, a TPU intended holster for the Maytech controller.
Search for strepod
Good news, the APD 120 F3x survived! Now I need to seal up wherever the leakage currents are coming from…
