What do you think about Makerbase VESC 75200 ?
It is at incredible $91 price for the 84V/200A + alu-pcb(better cooling).
It’s disadvantage is size: 130x68x28.
I see many people struggle with VESC, that is what pushes me away. On the other hand there are many people that use it successfully… But this is the only practical way to receive telemetry.
@rttn I saw that you were using the Makerbase 75200
At least they don’t explode during the detection procedure like previous versions of controllers. I can’t say anything more, as long as they worked, they worked well. Both are currently burnt due to a few drops of water.
@lishine
Quite a few using 75200 here. I have one, works well. The issues with vescs can be related to many things, i know some earlier 75200 were sold with incorrect resistors, screwing up the motor control.
In general, the vescs aren’t plug and play, they need to be set up (which isn’t hard really). I think setup is the cause of most issues. You can also damage them with just a wrong setting, they are not user fault tolerant.
And it is still a low-cost chinese electronic product… maybe i’ve been having too many esc:s that died but i’ve come to expect that esc lifetime is generally less than two years (for any hobby esc/VESC) if you really use them.
I have a Gong mast (monocoque old version) that I would like to try with this pod. Since I don’t have CAD skills to even modify “complex” shapes I rely on you skilled guys
I first printed a quick 10% infill of Strongarms original, with the Armstrong profile, which doesn suit Gong at all. I also noticed the section behind mast was quite thin, and from previous experience with another “sturdier” mount, the starting torque of the motor broke this part (I changed to 100% infill in the rear which sorted it out). so it might be a good idea to ad a couple mm rearwards to make it solid. Looking at your version with cable guide looks even more fragile because of the cutout, but hard to say. Or maybe I’m wrong…
I dont need the cable guide, so I would appreciate if you can make an STL without it, ie just original with Gong profile?
Flycolor has a new watercooled ESC reference: the KRAKEN tailored for RC marine racing use, with an optionnal WIFI module. http://www.flycolor.net/index.php?c=category&id=215
Limited to 12s, the price is much higher than the X-CROSS:
Compact form factor : ca130 x 58 x 20 mm
Kraken price for 120/160/200A cont : 222 / 245 / 335 USD
Mobile APP programming and parameter setting APP programmable, real time data being monitored: data recording (current, voltage, rmp, temp etc…), needs optionnal part, the Flycolor WiFi Trans (25usd).
Maybe not perfect fit, but much better than Armstrong profile which bends inwards in the front. In any case, now the people with Gong HM masts have a non-cable guide option.
I think folding propellers are not needed on the Tow Boogie. Shock load on the blades every time you press the gas - for what? Foil Drive Assistant is a completely different matter.
I used a 1/8" diameter aluminum Cotter pin in the pod (two holes shown). Hammered the loop of the cotter pin flat, then trimmed the excess. Then, I used a pair of M2 pan head machine screws in the holes in the clip itself, leaving about 5-10mm of threads exposed. That way, I can ‘snap’ the head into the strap, then pull the clip back until it engages the cotter pin. I would recommend an M2 Socket head cap screw, I just used what I had lying around.
