SoEFoil
August 16, 2019, 11:09pm
204
Aloha to all
im building now props for Maytech, flipsky and reacher motor
i want only to know how many you want so nobody will stay empty hand and then will again say that David its not nice man because cant delivery
quality its realy HIGH:
Aerospace ALU
high quality surface treatment (more than 50um)
polished props
perfect balanced
and which color you prefer:
Shaun
August 25, 2019, 7:31am
206
They look amazing as per usual! How much are they, please?
i have not yet make a price
its more people gona buy less i will go with price
lets say that:
5 props (-5% discaunt)
10 props (-10% discaunt)
15 props (-15% discaunt)
20 props (-20% discaunt)
25 props (-25% discaunt)
and then STOP
becuse mybe ho will order 100 props and then geht all for free
Hi David,
What’s the pitch and diameter?
Cheers
Diameter : 152mm
Pitch : 7 inch
michion
August 25, 2019, 7:48pm
210
Yes please. I’ll take one in blue or black.
Hi David,
Did you run some tests on a Maytech/flipsky/reacher or is it just a standard size you are using on the FR motor? If tested what kv, voltage did you use?
The only feedback from real tests with these motor is from Virus at 100kv 12s, he used 130mm and 5" pitch.
I’m interested, just wondering about the size.
Cheers
I want my standard prop modification and fit to mytech motor…
michion
August 26, 2019, 6:15am
213
Sounds good to me, where do I pay.
Can you tell im keen on one.
Do you know that it will work with flipsky motor? then put me on your list for the props, too
Jezza
August 28, 2019, 6:37am
216
I’ll do this deal David. I have a 120kv maytech motor to test the prop on.
michion
August 28, 2019, 8:36am
218
Ive got a Reacher Tech 80 KV waiting here for your prop.
Im in.
You do not need to refund anything if it does not perform. I am happy to accept that risk
And I get flipsky 120kv next week, would take the offer as well and test the 2 props, no refund necessary if it does not work;-)
I’m IN !
I’ve got one reacher 80 Kv and one Reacher 100 kV and I would definitely love to try it out with one of your prop !
Be the fastest guy in the Town
I wish FAST flight to all this new owners
V_S
August 28, 2019, 6:12pm
222
I would try it on the 80100 and René’s Foil if you want…
Can i make such prop fit to my 63100 class outrunner motor on my lathe? I would take two to get it done within time. Plan is to build a setup in 3 weeks.
