I always do the “shallow water fall” technique. Protect your feet, knees, and most importantly your head. I foil in waves and over shallow reef with sharp edges and “Wana” that will painfully get stuck in your feet so I learned early on how to fall in 1 foot of water without hitting the bottom.
Never dive off the board when you fall. When the foil hits something you can’t see, you should still have over a foot of water depth. This is plenty deep to shallow water fall without hitting the bottom.
Glad you survived. I hope the board is ok. And yes. The buddy system is the safest way to ride.
Thank you for sharing your story. It reminds us all how dangerous this can be.
Even with perfect reflexes and luck i wouldn’t have been able to choose my fall, waters are black here and i was going full speed in the middle of a small lake. One moment riding , the next ”is my head still attached?” Where am i? … Fumble fumble, blood clouding my eyes.
Nice falling tip though, i’ll try to work it into my muscle memory. Double !
A Flipsky design of the prop will look something like this, hub diameter ~53mm, shaft 12mm, overal prop diameter with these blades grows to 161mm. Is this something usable?
Has the FR prop for 12mm Flipsky motors a 8mm/12mm hole? 12mm deep enough for the main shaftdiameter and 8mm for the threaded end to fit through? The hole in the blue FR prop seems to be 8mm from the picture.
just a question about the weight of a FR props? What is it? For le the alu Yamaha standard props After lifting is 150 g at 6 s no enought power my pla print is 55 g with époxy , for help the motor i think light is right for spinning faster easily?
Today I was on the water again, and I’m really pleased with this prop
Both the smooth propulsion (fast on plane) and the effiency are good (way better than I’m used to). Today had the longest flight with my setup so far, 13.4km distance. With previous props this maxed out at 11.5km. The only thing changed was the prop, so a fair comparison for efficiency.
Just finished testing a prop I generated through the caeses app. Runs way better than the alloy Chinese prop I was using. Running on a maytech 65162 100kv.
I am a bit out of topic as I am building a E sup (Hydrofoil are banned in Switzerland ESUP too but it is more discreet)
I will use a SSS 5694 600kv in direct drive… How do you remove the hub in “B-Series propeller” from Cases? As I am looking for an 80mm prop the hub is larger…/
Is there a rule for having an estimation of the rpm under load?
No rule, if the motor is loaded enough it will stand still eventually. On ebikes i usually assume 85% of unloaded rpm, has served me ok so far but it’s more assumption than reality. for props it’s harder since torque needed is squared with rpm and torque vs blade diameter is to the cube so you can easily overload your motor.
I think you will not get enough torque with a 600KV direct drive, either go geared (5:1 with 12S, 420-600kv) or use a 65162 or 8100 outrunner (wet setup). Or build a jet with direct drive.
Yes I am wondering this. But I will use a low pitch and a low diameter (between 70-80mm)
It seems (I am not sure) that people use 700-800kv on jet with a diameter ~63mm 4 blades and a lot of pitch…
