Hi folks, being the request for 3d printable prop always actual and maybe interesting either for newbies than seasoned Efoilers, why not to gather here some design for the community?
Let’s start.
I do design with Solidworks starting from a JavaProp sketch, 3d print in PC-Max (polycarbonate) or even in PLA and then I smooth the surface with sandpaper and epoxy. If the blades are thin (desirable for performance/efficiency) I do laminate a patch of fiberglass on both sides, just to reinforce the junction hub/blade, doesn’t matter to cover all the surface, after I will smooth all by sanding and glassing with other epoxy. Takes some time and effort but the result is worth that extra sweat.
140-230
this will be my next.
This have make my fellow efoiler very happy:
142-216 stl
142 216 solidworks part
The hi pitch one, tested by some users already:
148-305
I shared also a prop for 80100 outrunner, @MaxMaker tried it I think:
80100
Now some render of the first listed, which I’m eager to try!
Just as “disclaimer”, I use a race type kite foil (580 Moses Vorace wing), big kite-race Royal board (dinosaur from a forgotten era), long mast (1mt) and 360KV + 4:1 SSS/Neugart combo, powered by 12s Lipos for now. Last but not least, I’m not even 65KG… which make sense for what above.
New design will come, I wish this could start a good thread.
I’ve some “Solas outboard 71/4” design also…not tested on Efoil but on a boat… if anybody what to give those a try. Diameter 182mm however…and the hub is the original.
