I don’t know, it’s other builder photo. Regular one side hole is enough
SOOO COOL DO YOU MIND TO SHARE THE FILES ? THX A LOT
step files here universal motor mount for efoil
Super cool! Thanks for sharing!
Really cool. Thanks for sharing. Do you think the sides of the motor pod could be screwed into the aluminium rear part of this motor mount to avoid drilling into the mast?
Yes
You can
But holes in the mast will strengthen the motor mount and prevent it from moving under vertical loads that may occur when performing tricks and flips. a plastic sleeve in this place is recommended
Hi jkoljo, i am building an e-foil and have been looking for some decent motor-mount ideas. i need look no further. Absolutely great designs and workmanship ! Thanks for the input
Do you have the modified mast clamp for Fanatic?
I have the Fanatic AL 3.0 and want make a mast clamp for the 6384 motor.
@Savoie hi I have the right profil for Fanatic AL 3.0 (Gong_V2_mast_rear_clamp_rev2_fanatic_AL3_v4.STL) here the link of STL Dropbox - Gong_V2_mast_rear_clamp_rev2_fanatic_AL3_v4.STL - Simplify your life
And the SLDPRT your can convert for your software
Hola, que hélice estás usando? La hélice que tengo del Flipsky 65161 es grande para el protector impreso que se habla aquí, estoy buscando hélice más pequeña eje estriado de 12mm
Hello,
I have been designing this mount the past few days, it’s still in the prototyping phase, please comment on it, critique it. Some info: It is connected with four m5x180 imbus normal head screws, the thread for attaching the nose cone is designed to be 3d printed. The water cooling channel is designed to fit 8x6mm pneumatic tubing. Both cables and the hose will enter into the mast through a hole (can be seen on the model). Also based on the @Larsb mast model. The aim here is to not have any visible screws or so…, can also be fitted with a nose cone without a hole to “disable” the water cooling. Please do comment.
Hello @jkoljo ,
Maybe you can share 3D print file propeller shroud? ![]()
Hey, can you share the 3d files for it without the water cooling? Love the design, very simple and efficient!
There you go: foil assist mount for maytech 6374 motor and gong V2 aluminium mast by sebdesgouded - Thingiverse
Ah that’s for a 63mm, I have 65121 sadly
Hey lkoljo, I’m having a go at making your design as a way to get in to Wing Foiling, learn to ride the board first etc. All is going well, and I would like to keep you updated.
Great work and many thanks ![]()
I am creating another mount for the 65161 that is more streamlined and should later be made of carbon fibre:
Does anyone have a mast motor mount for the 65161 motor and Gong V1 mast (should be same as Naish Thrust Alloy and one of the Cloud 9 alloy masts at 110mm x 15mm) available for sale? I do not have experience yet with 3D printing but am good at adapting and simple machining. This is the last piece of my DIY efoil build. The powertrain is working on the bench. Thanks, Steve in California
You can try this one:
It was made by @jkoljo some time ago.
I used the version for Gong V2, it has worked well printed in PETG. My first version I did was pla+ and that was too brittle and cracked at the back of the mast after a few months
Actually just noticed you were asking for one for sale. If you don’t find one for sale you could just use an online printing service and then it’s really not hard at all to assemble
