I dont think it will fit a 14S14P, but it will fit 14S12P I think.
It is the max004 case. You can get it from quite a few different places.
I don’t use it for the battery though. My battery is open now inside a hatch.
Im not sure I understand how you bypass your BMS ? how eactly is your 150A output fuse connected ? I have found it difficult to find a BMS that can take hign amp output draw. I think this could solve my problems
I only use the BMS to charge and balance the battery. During normal operation it is not attached.
The 150A fuse is the positive terminal of the battery.
I found out that although the balance charger accepts voltages above 8v, you won’t get the full amperage. The higher the input voltage the easier for the balance charger to have the full ampere available. That’s why I switched to a 24v power supply.
This is my favorite one. It can supply 12v at 75a continuous. I’ve done 75a for 4 hours no problem. Do the mod so you can hook two in series and you can do 24v / 75a.
Depends on how fast you want/can charge.
I hooked up this one to 2 of my ISDT’s. I now charge my packs at 500w each, this is healtier for the batteries.
I found out this one was more quite as well, im happy with it, though I would have liked the oppertunity to charge both at 750 (1500w total). So maybe the option with linking two 12v supplies is cheaper and better.
Be carefull here guys, overcharging 18650 makes a nice fireball… And I’m not making a joke here.
You need to consider the max voltage your batteries can be charged at… Also you shouldnt charge with more current then about half the capacity for long life of the batteries… So 6s @ rated charging current of 4,2v per cell with lets say 3500 mah capacity = 25,2 volts 21Ah in total… Pushing in no more then 10,5 Amps or about 250 watts…
An easy metrics I remember for li-Ion cells: charging 1 or 196 in a 14s14p battery should take at best 2 hours because of the charging capacity that should not exceed 0.5 C (half the nominal capacity). I’m a bit scared that Waydoo announces 1h charge time for their nxt July production.
The game changer for rentals will be using small LTO cells that blossom on Aliexpress: same capacity as Li-Ion but a charging capacity that can reach 2C and 1 hour divided by 2C = 30 minute per charge for 1 to 196 cells. The unknown being the power of the power supply. If you multiply by 4 the charging rate, you multiply by 4 the charging amps and that can be high.
I also charge at about 0.5C. I charge 35Ah 14s at 14A so it is even lower. For my work I use a lot of makita cordless tools. They use the same cells as we use (samsung cells). Most of these batteries charge in 30 minutes, so 2C. The charger is blowing air between the cells. Should it be possible to use a higher charge rate if we can cool are battery packs good enough?
I am using the makita double charger too, on 4 batteries 2 are dead after two years and approximately 20-30 cycles max… the quick charge is a need when you need the job done but it kills the battery life
I did a Samsung 35e pack with 12s12p I choose to charge it at 0.25C and always leave 15-20% juice in the battery no problems so far…
