My name is Maxime, i’m 25, i just graduated from micromechanical engineering in Neuchatel Switzerland. I will be living there soon and guess what : the city is in front of a beautiful 220 km² lake
I’m equiped with a 3D printer and a 3 axis 6040 CNC. I already built 2 eskate and now i would like to go for the efoil ! The build is going to be slow (i’m always slow because i have tons of projects at the same time) but i will focus on making something with a great design and quality. I will also try to make a good video to show all the building process.
Actually i’m finishing the CAD. Here is the final design :
Foil: Horue VINI Pro XLW wings
Those french made wings are made for a low speed take-off and optimized for good stability at high speeds. I got a 30% deal at blackfriday but still expensive (400€). I really wanted high performance wings (no chinese foil) and i hope this is worth the money !
Board: Homemade from an EPS block
The 40mm motor will be integrated in the tube connecting the 2 wings (@Peter’s style) which i believe is THE way to go to lower the drag and save energy. I will try to keep the tube in 1 single piece to optimize weight and rigidity. I have some good ideas to make it waterproof and i hope it will work.
I will first build the board so it can dry a few weeks (or months ) during the propulsion system build. Also for now my budget is really limited so i can’t buy all the electronics/motor/reductor at the same time…
Hi!
I’m from Neuchâtel too! Me and 2 other friends from Neuchâtel and Bienne finished our efoil last summer and I efoiled in Serrières until october. I had to disassemble everything to make some reparation so it can be interesting for you. Give me a call: 078 908 91 70
This will help me to get fast access to the charging ports, no need to take 10 screws out to charge. It will also house 2 voltage testers to check the cells voltage when riding (because i don’t want to use a BMS for discharge).
Next step is to make the 2nd enclosure and stick everything together with epoxy resin.
And to finish i need an advice : should i renforce everything with fiber before integrating the module in the board ? (like @Mat) or should i integrate it directly in the board and do the fiber work after ?
Thanks !
great idea with your small access hatch… do you think the fast button will be strong to keep the lid tight on the seal?
If you plan on vacuum bagging the fiber on the module (more fiber for the same weight so more rigid). it will be easier to glass it before, a bag for a full board is a pain …
Also, if your CNC can cut epoxy, you could get a much better finish by glassing it, add and extra coat of resin, and machine it back to the exact dimensions you need…
Next step is to make an “insert” in the tube to hold the wing with 3 screws. My idea is to put 4-5 stripes of carbon fiber inside the tube, let it harden, then drill the 3 holes, put 3 nuts inside and cover them by a big coat of chopped carbon fiber which will fill at least half of the volume above the wing. Like this :
Thanks for your answer. Haha yes the shape is strange but i believe it’s a really good wing, i hope to get a low consumption setup
I will ask horue, but i read on their website that you can play on the rear wing incidence so i imagine that the front wing is horizontal or with small angle like you said.
Hi Max, wonderful job, this looks really promising !
what is the thickness of your aluminum tube ? Are you sure it will handle the lifting force correctly ?
thank you
not sure where, but remember seeing that you shouldn’t put carbon directly in contact with aluminum… you may be ok with enough resin in between or a layer of fiberglass to isolate…
It’s the @Hiorth propeller but in a 3 blades version. I calculated the pitch and it’s 8.5" if i’m correct. I will also print a 4 slot central part so i can swap if i want.
Next step is to sand and make a smooth blade surface, then i will make a mold to replicate the blade 4 times. First i will replicate them in high performance urethane resin specially made to make strong thin parts (task 9 from smooth on) so i will have 4 blades with the exact same weight which will give me a well balanced prop.
Then i will try to replicate them in carbon fiber but i don’t know if it will be easy.
So this is my first mold ever, it’s more complicated than expected… i need to order harder silicone, this one is maybe too soft. I will make a try with some carbon fiber soon
I have searched the internet (breifly). I have not found any information advising not to use aluminium and carbon fibre together. Do you have a reference @Mat?
