Mounting everything downunder - done before or just crazy?
Still reading many threads and learning from this great forum, with the final goal of building a still-water e-foil.
This may just be plain silly, but has anyone tried putting everything on the under surface of their board? This could allow one composite module to house the battery, electronics and also mount the mast to.
Here is what I mean:
For the module, I’m thinking composite construction over a mould. Seals made by pouring silicone into each built-in seal cavity. Cover plates held by screws into the composite.
Thinking battery charging via BMS and a charging connector port on the stern.
Waterproofing (obviously) would be critical, there will be more water pressure on the seals than normal. Seems silicone seals well-made could be up to the task? The main reason for considering this is keeping all the major components in one pre-built module, that could be dropped into the board. Very roughly like the much smaller standalone add-on assists, that mount between the mast and board (foildrive.com.au).
Just kicking ideas around, but has anyone tried this approach?
There is a commercial build like this, pwrfoil:
You can actually purchase a carbon section that goes under board from Alibaba (It looks very similar to PWRFoil). I can’t remember the manufacturer name though.
Many thanks for the feedback and product-directs guys :+1:
So not completely crazy :thinking:
I certainly wouldn’t describe the PWR-Foil’s under-surface as “laminar”, so good to know a perfectly flat under-surface is not required -
PWR-Foil_1
Sealing the battery, rather than the battery-box, is clever and probably easier. I’ll think further on that.
Looking like a concept worth pursuing :grin:
The first company to implement the hatch flush under the board was Pegasus, a Korean / Singapore company in Apr 2019,
Nov 2019, the PWRFoil rev1,
Spring 2023, Mantafoils with their Volt4: https://www.mantafoils.com/volt-4
https://www.mantafoils.com/online-store/Volt-4-eFoil-Complete-Kit-p534805091
Here, the Mantafoils Volt4 thread with the wingfoil kit and the JetsurfingNation test video :
'The Volt eFoil thread - information for the DiYer - #30 by Mantafoils
or if you can
Also, in case you didn’t notice, there is also a recent build by @hangloose. He has mounted his battery and esc in a metal box on the bottom of a modified prone board.
Thank you! I must admit to dropping in to hangloose’s project some time ago, but not clicking that the board was upside-down :man_facepalming:
That’s a very nice build. So much talent on this forum, it blows me away.
It’s a very tightly packaged build. I think it succeeds an efoil because of the Molicel P42 cells having the energy density and a good punch of current. Also I think the metal box is important for heat dissipation.
