New Direct Drive Inrunner 65150
You need to set the correct pole numbers in the logger to get the correct RPM data. It appears you have the poles set to 2.
If I remember correctly this motor has 6 poles so the RPM data needs to be divided by 3 still.
Therefore Max RPM in the graphs would be 12768/3 = 4256.
Considering the voltage is 42.4V I’d say your motor is more than 100Kv.
rpm 6 pole
Isn‘t there a need for a „thrust bearing“ in this setup?
I only feel a little cavitation when start, the rest of the ride works well.
This is the video with 140mm prop 100kv motor
Fron The Graph above it looks your avarege current is around 70-80A.
Do you have comparison to your geared setup?
This looks like they are simply labelling the 120Kv motor as 100Kv!
At that RPM and assuming it is actually 120KV it would be giving an efficiency of around 88% which would be about right.
It will be very interesting to see what speeds you are reaching with this prop and whether it can handle 6" and 7" props well.
What OS are you using on your PC for downloading the logs? I had issues with my swordfish 300A, although I’m convinced it was defective anyway as it would only start up the first time and then not again until I powercycled it.
  • voltage recording can be off by 2-3v
  • thr and remote need to be set at 99,9% if we want to use the numbers
  • rpm off load: battery voltage (checked) x thr (100%) =erpm/nb of poles , then you find your kv or the nb of poles…
  • max rpm should drop on load by 20% at least
  • current measured is probably current motor, so it is hard to know and compare WH since most measures here are made on the battery side
anyway this set up works
Yes, I have the Nick VESC and Maytech vesc6 200A but I need a few days. I have a lot of work in this moment.
hello Virus,
Thank you
Maybe he made it smaller or he means pitch 140mm. I know the pitch is 138mm.
If you look closely at the pic you can see it’s been cut down to 140mm
https://flipsky.net/collections/efoil-products/products/brushless-sensored-motor-amphibious-fully-waterproof-motor-65161-195kv-6000w-for-efoil-ejet-boards-ebike
$760 for 195kv.
https://www.aliexpress.com/item/33055746076.html?spm=2114.12010612.8148356.4.1119435csHKnRI
Do you have to contact them directly for custom 100kv motor? and how much?
I don’t think the pitch is changing, becaus the angles of the blades are still the same. The prop wil turn faster because there is less resistance from the prop tips, but there will also be less thrust at the same rpm and there for more slip. But it could be better for your motor to not overload it.
Most propeller have variable pitch , when you cut you change the average pitch ( lower) but a lot less the thrust so you get more rpm and it compense for the speed
