Isn‘t there a need for a „thrust bearing“ in this setup?
I only feel a little cavitation when start, the rest of the ride works well.
This is the video with 140mm prop 100kv motor
Fron The Graph above it looks your avarege current is around 70-80A.
Do you have comparison to your geared setup?
This looks like they are simply labelling the 120Kv motor as 100Kv!
At that RPM and assuming it is actually 120KV it would be giving an efficiency of around 88% which would be about right.
It will be very interesting to see what speeds you are reaching with this prop and whether it can handle 6" and 7" props well.
What OS are you using on your PC for downloading the logs? I had issues with my swordfish 300A, although I’m convinced it was defective anyway as it would only start up the first time and then not again until I powercycled it.
- voltage recording can be off by 2-3v
- thr and remote need to be set at 99,9% if we want to use the numbers
- rpm off load: battery voltage (checked) x thr (100%) =erpm/nb of poles , then you find your kv or the nb of poles…
- max rpm should drop on load by 20% at least
- current measured is probably current motor, so it is hard to know and compare WH since most measures here are made on the battery side
anyway this set up works
Yes, I have the Nick VESC and Maytech vesc6 200A but I need a few days. I have a lot of work in this moment.
hello Virus,
Thank you
Maybe he made it smaller or he means pitch 140mm. I know the pitch is 138mm.
If you look closely at the pic you can see it’s been cut down to 140mm
$760 for 195kv.
https://www.aliexpress.com/item/33055746076.html?spm=2114.12010612.8148356.4.1119435csHKnRI
Do you have to contact them directly for custom 100kv motor? and how much?
I don’t think the pitch is changing, becaus the angles of the blades are still the same. The prop wil turn faster because there is less resistance from the prop tips, but there will also be less thrust at the same rpm and there for more slip. But it could be better for your motor to not overload it.
Most propeller have variable pitch , when you cut you change the average pitch ( lower) but a lot less the thrust so you get more rpm and it compense for the speed
Disagree
Example:
My 300mm pitch prop has a 50mm hub length.
The tip of my prop moves forward 50mm every 30 degrees of rotation.
6x30=360 degrees, 6x50= 300mm pitch.
As the diameter decreases from tip to hub, the angle must increase to maintain 50mm of forward movement for every 30 degrees of rotation.
The blade at the hub reaches 300mm in 1 rotation just as the tip does despite travelling through much less water.
Propeller pitch is not just an average of the varying blade angles. The blade angles are a function of different velocities across the blade at different diameters from hub to tip.
Wish I had a diagram to show, it would be easier to explain.
…and before someone says it, prop slip isnt factored when measuring prop pitch.
Angle and wide of the blade give distance , every propeller that I measured , FR , solas , Yamaha from center to the tip had variable pitch
Measures were taken from the front to the back of the blade every 10mm increase in diameter
I agree with you we have to take the rotation speed of the part af the blade as well , pitch increase , speed as well , area decrease , I guess it gives the same thrust across the all diameter
