There are quite a few options for the motor. It all depends on how much power and speed you want to board to have. I just wouldn’t try with less than 3KW.
A dual drive setup would probably work, but would introduce a lot more drag and would be less efficient.
Yes you could build the foil like Clearwater does. Ultimately you can use whatever material you want to built the foil provided it is stiff and strong.
Prices are going down: if you don’t want to buy from China, you have alternatives such as The ALLVATOR aluminium foil from Gong at 399€ shipped from France to Europe without custom Tax and possibly 332€ without VAT if shipped to outside Europe. Add 20 to 30€ for shipping, that’s less than 370 GBP delivered to a UK door.
This ALLVATOR for kitefoils is pretty unique as its front wing is quite wide (65cm) ensuring early takeoff and stability and a max speed of 20+knots. Front wing surface is around 900 square cm (less than a SUP 1200 cm2 and more than a kite 600cm2). Should be very good for efoiling.
Downside: available end of July 2018 only if pre-ordered.
Brand history: Gong has been making boards since 2001. They have been developing, manufacturing and selling their own hydrofoils since 2014. They stock their spare parts.
Not so much to my knowledge, maybe Manta foils but not sure. True question would be why chosing a VESC for a commercial project, it’s still advertised and sold as “test unit”, you don’t have any warranty on it…
Because I would like to expand Metr app (https://metr.at) into foil market a bit more and have a foil for testing, I also think it is super fun to surf!
what type of connector is on the antenna extension? - the PCB side. Reason for asking is i have 2 antenna (IPX13) already installed into the nose of my board one for remote and the other is spare. i would like to use the spare for my metr module but unsure if i need an adapter
New builders ! We know it’s not always an easy task to find answers to your questions, especially because it has been answered many times before on so many threads that it’s not possible anymore (or difficult) to find where / when precisely.
Feel free to ask anything here, I’ll try to help you as much as I can and hopefully other expericenced users will follow later. Don’t be discouraged, we started like you ! I personnaly spent one whole week of reading before even registering on the forum !
Hi there all,
I just want to make my first basic question.
I so a lot of board design and sometime in the detail I so the volum of the board in liters.
My question is… if my weight is 95kg, I need to make a board of at last 95 lt volume,
(plus battery weight, electronics etc…) in order to have a piece of board out of water ?
Are you sure all inrunners require a gearbox? I’m just a baby in this field but as far as I’ve noticed here, for example, the Flipsky 65161 motor is often used as a direct drive.
For a beginner, the consensus rule is a minimum of :
rider’s weight (kg) + 30 kg for (board + battery+ foil + wet wetsuit) = 125 l
If you want to start in comfortable conditions, stand on a floating board and “have a piece of board out of water”: add 30-45l = 155-170 l for you
After a couple hours of practice, you will appreciate it is only 130 l because you will have gained some riding experience.
This being said, in an early July (21) video, Supernova (back to life) takes off with a 150x45cm board with only 60+ litres using a special take-off technique.
I have some family and friends taking out my board which is 90L. A bigger board would have been far easier without having to worry about submerging and losing reception. I’m going to build a 125-130L board next (that I can also use for wing foiling as well)
