Pacificmeister Build Info and CAD Sources
The motor-gearbox mount sits pretty tight in the tube with the 2 o-rings. The thrust pushes into the tube but it’s a good idea to lock rotation. In my first version I did it with a couple small short set screws perpendicular through the the tube into the mount, water side of the o-rings. In a later version I just used tape, worked too. My fit was pretty tight. The wires should not take any force and I have no motor-mount-bolts on the mast clamp side.
What are your thoughts on battery pack size and your current runtime with your 2x 22,000mAh?
Would you prefer more run time like 30,000 or 44,000mAh or would you rather swap battery packs to keep overall board lighter? Thanks in advance
Me personally I’d rather have a not too heavy setup and swap more often. Am happy with my batteries, their weight and runtime right now, they last maybe 30-45min.
@pacificmeister What is your current battery configuration?
2x Tattu 22000mAh 6S 25C Lipo Batteries in series
Hi everybody,
Somebody could give me the characteristics of the threat of the sealmont ? I would like to build this in aluminium and this must be compatible with the duct. Thanks
Is 25C the strict minimum ? Or would something like 15C be enough ? The reason behind my question is that now graphene batteries at 8000mAh 6S 15C cost 68 euros… Meaning that 24000 mAh would cost 204 euros, that is less than half price compared to the Tattus. Considering that lipos batteries have to be thrown away 3 times quicker than graphene batteries… That would put Tattu’s price down by 6 times.
Graphene batteries have larger dimensions though, if I am not mistaking.
https://hobbyking.com/fr_fr/turnigy-graphene-professional-8000mah-6s-15c-lipo-pack-w-xt90.html
How many amps are most people pulling? I’d imagine it would be a lot lower when you’re actually foiling. A lot of batteries have a peak discharge that is higher than the regular discharge which could be used to get foiling.
On the graph bellow I have plotted the Amps vs Speed in Km/h curve
I have a takeoff speed of 17.5km/h, the most efficient speed of 20km/h and a top speed of 31.5 (I am 85kg and using a drysuit so about 90Kg)
Unfortunately, I have burned my EagleTree elogger heavy duty after a few run.
SpAmp
I am using the Hiorth v1 with an Alpinefoil Access v2 and a 900cm2 wing
My PLA prop is barely sanded so this can be improved
SSS56104 500 kV
ESC Alien 400A 3-16S Boat ESC HV
12s (2X TURNIGY GRAPHENE PROFESSIONAL 12000MAH 6S15C)
http://www.alpinefoil.com/kitefoil-windfoil-shop/ailes-foils/aile-windfoil-alpinefoil-ulw900.html
So you are using those Turnigy 15c graphene batteries… Great ! What is your feedback about it ? It sounds like this is enough to push you out of the water …
Price is 135 Euros at HK. Meaning 270 Euros for 24000mAh at 6S
Yep, they works well. 12000mAh*15= 180Ah and I pull max 140Ah. If you use 4 you could have 280Ah in discharge rate, that’s my plan for my next build.
Just keep in mind that they inflate a little so you shouldn’t have them too tight in the box
@Just, thank you. I corrected it.
@Clarin : which charger are you using please, and how long does it take to fully charge those big mamas ?
1hr 50min @ 6A with SKYRC ULTIMATE DUO 400W 20A
I could charge them way faster, but I prefer to be safe
That is fast enough to me ! 1h50mn is only a French lunch time :wink:
Hello
I’m looking for the tutorial to desin my own mat with 360 ​​Fusion on clamp, if someone remembers the location, thank you
it’s good i found on youtube
If I read this right, at 24 kph you are at ~70 amps. I’m about the same using the SSS 56104 360kv, Parker 4:1, 130mm x 215mm 3D printed prop that is sanded and painted, 14s battery, Alien 300A boat ESC.
Based on Pacificmeister’s data, the Flite Board website, and the Lift pictures, they are only using about 42 amps to go 24kph. I’m wondering if anyone has any idea why some of us are using 70% more current than others. I’m fine buying more batteries, but I want the most efficient system I can get! I doubt the Seaking ESC is that much more efficient.
Yep that’s correct. The 70% difference on my case is the prop and the prop guard. Once my prop guard broke while riding and my top speed increased from 31 to 37km/h and I am sure that with a good aluminum/carbon prop I could have reached close to 50km/h. I guess that’s the difference?
Could you help me to choose the good position of the “black square” ? to have 5v on the receiver.
