Have you thought about using a cheap plug in blanket to wrap your glassed projects? I’ve used it and it seemed to work well. It’s also very economical.
I use this oven to keep a temp of 30º with foam, IR lights, reflecting sheet and thermostat. Maybe a little box for little parts.
We did them too.
We used a big balloon for the nose cone. After wrapping the CF we put it inside the balloon so it was nice and tide inside.
Are also putting a layer of carbon on the motor? We did not, but for sure it will look nice when done.
Wow. That is nicely done
Are those mc4 connectors? If they are I would think they’d be a pita to take apart.
Mini Waterproof Connector IP68 Outdoor Wire Small Waterproof Connector for 3 core Cable Straight-Through Head Outdoor Waterproof Connector Cable 2 Pack Amazon.com
Nvm think I found them. The. You modified inside for 8mm bullets I guess?
Thats it. Sure 8mm bullet inside.
I think this connector CNLINKO will be great. I will try with another bullet conector. What I have are too short.
Those CnLinko waterproof power connectors look fine for our application.
I really love it! Works with little changes for me.
Some of you tried with this case? Internal space for size 3 is: 330x220x70mm. I am not familiarized with battery building. I wonder wich battery is suitable with these dimensions. It says is suitable for 12V. But I think maybe for bigger batteries is good. I am looking for battery 44V and 30-40Ah.
Hey, can you please elaborate on how you changed them to fit the high amps we use for efoils? It looks like you changed the inside plug.
Just replace the 2 original cylinder with grey case for 8mm bullet connector. I printed the grey case with a resin printer.
Internally, the principal case has these components. In these component you can remove original black cylinder and replace with grey cylinder (3d printed).
This is the original black cylinder or plug that would be replaced with grey stuff
The result:
Algun fabricante de baterias Li-ion de confianza y que me puedan recomendar en España. Vamos que no se queme! Si es en Barcelona donde vivo sería mejor. Busco bateria 13s12p Samsung 30Q para mi efoil. Con BMS minimo 150A. Gracias
