Redpinelabs board #2
Yes, but I’ve only unbalance charged so far since I doesn’t come with cables to balance charge without making them. I’m getting PCB sent out soon to make an easy balance board.
I have a BMS I am designing so I was using a prototype to balance the battery every few charges (since I got to pull the battery out the box and replace the tape). I had do a few cut and jumps to make it work so I didn’t want to put that in my battery case yet until the next version. I charged at the full 1100W parallel charge (for 120V). I was going to make a 240V cable so I can 1800W parallel charge (~30-35A at 14s).
I did update the FW on it. There was a later version then what it shipped with, needed to use their windows app for that.
Also pyrodrone has it on sale for cheaper: https://pyrodrone.com/products/isdt-x16-1100w-20a-2-16s-ac-dc-dual-channel-ac-smart-charger
I like it a lot better then hauling around my icharger 406 and power supply so far…
I’ll do a full review when I get some more time on it (with balancing).
I got in some connectors that I crimped up to balance my 12s split into 2 6s packs. Leaving tomrrow for a trip. Balancing seems to work well. I had the current drop to like 15A after running awhile though, not sure if it is trying to do something smart based on measure IR or something. I’m going to try and contact IDST
compared to icharger 406 - which I only have a 12V supply now, so can’t do that much current.
Managed to hit 26.2 mph (42km/h) on my 14s pack and happy foil wing. Probably could still had room to go a tad faster, but didn’t want to crash!
Nice build!
I am in the process of building mine, but waiting on some parts.
Do you get out to Breezy Point much? I have a cabin on Pelican. It would be fun to go foiling some time.
I used to live in breezy point and crosslake, so I used to kiteboard at breezy point, the south end of the lake at the public beach, or the southeast corner at a friends house (before they moved). I’m really familiar with the lake! FYI don’t foil in the breezy point bay - completely full of weeds!
I now live in Colorado but I work for a company in the area, so I’ll usually get out there several times a year. I’ll be there in early January, but I don’t think there will be much efoiling then :smiley:
I’m sure I’ll be out this spring sometime and it would be fun to meet up!
One goal for the summer - I’d like to hit up crosslake and efoil to moonlight bay and the wharf for a dockside beer :beer:
Haven’t seen anymore updates about this X16 Charger, are you still using it and can you recommend it?
Do you also charge your Li-Ion batteries to 4.2 volts with this charger even though they are normally only charged to 4.1 volts?
Yes I do recommend it,
All my li-ions are rated for 4.2V a cell so I charge them up to that. You can set it to less or more a cell if I remember right.
Been balance changing my 12S12P 18650 pack with it. My 14s10p 21700 pack with BMS ( so no balance charging). As well as other onewheel/scooter packs. Been a good charge everything charger that is pretty compact.
I also have it hooked up to 240Vac now for better efficiently and higher current. I have run it off my generator at 120V as well and it seems to work well.
Got my longest ride yet. 18.4 miles in my 14s10p 21700 pack. Brought the pack down to about 3.4 a cell, so probably could have gone a little longer.
Been riding the Phantasm PTM 926 I got for winging. That foil is way more efficient on the water then anything else I’ve used. After recharging put about 2927Wh back in the battery, so I did about 160Wh/mi (100 Wh/km) overall efficiency. I wish I could get those numbers out of the @WavRX though!
Cut a slot into the board and moved the antenna up to the nose then re-epoxied it. That fixed my reception issues completely (it was easy to lose reception when just starting the board moving.
Redid the silicon seal and replace the hinges with the nice friction gemlux ones (GEMLUX Stainless Steel FH-9605-FM Friction Hinge 3" X 1.5" Flush Mount | eBay).
Got a phantasm adapter for my slingshot mast. Also messed with CNCing my own for my other mast
CNCed a phantasm bigfoot adapter on the liquid force fuselage. This should be a little more secure then my previous method.
Awesome stuff man :slightly_smiling_face:
Whats stopping from getting those numbers from iLogger? I can help you fix any issue you might be experiencing.
Last I checked the distance measurement on the logger was based off the motor spinning. For efoil that doesn’t work very well. Ideally, what I’d like is calculated Wh/mi (or km) vs logged GPS.
So I can look back and check see that when I was traveling 12mph I was getting about 60Wh/mi and when I was going 20mph I was getting 120Wh/mi.
Or I can go in an change foils/props (on the same battery) and see what kind of efficiency I get.
Something like this metr log I grabbed from here: Sep 22, 2019 - metr.at | UfSgd (Metr app records GPS data together with VESC data - #26 by V_S)
Looking at the consumption line:
Let me download my log from yesterday and see how it looks.
Oh I see what you mean. I noted that and will try to include speed logging off GPS on the next update. I think that’s the only thing left to be able to fully get the numbers you are looking for. On the last updates I added Wh/mi and Watts logging.
@WavRX I must have a bad gps wire on last runs? Or is there something else wrong? Any way to filter out the lat, long 0,0 coordinates?
https://api.wavrx.com/r/ac2fa289e9c19f90db7425bedac30768
Also could the Date on this page show the date of the log instead of the uploaded date? I’ll usually have a bunch of logs before I hotspot my phone and upload them.
Thanks for the report, this is definitely a bug. Can you please send me the log file in question?
Regarding the dashboard, that’s a good point, I will add a new column for logs date.
You need the raw file off the sdcard? Or can I pull it with the app? The logger is buried in my ESC box so it is a bit of a pain to pull it all apart.
No worries, I’m currently trying to reproduce it and I might not need the exact log. I will get back to you once I pinpoint the bug.
First day of the season and on the foldy prop!
hey mate, I saw that you have the hinges “barrel” prominent on your deck panel… had you ever had challenges on them being dangerous ? what hinges have you used?
Yes they were annoying when they were sticking up. I switched to different ones that are friction hinge and not prominent.
