Working on a new efoil board, a bigger one that is easier to learn on.
Build the wingboard in Oct 2021 to learn to wingfoil with. But later got a larger inflatable and smaller hardboard. So wasn’t using this anymore.
The plan is to use the same mast, motor, ESCbox as my other board:
And swap them between the 2 until I build another.
So put it back on the CNC and did a little surgery:
Had to work fast. 90F+ in the garage. Need to get an AC unit installed.
My slow epoxy was getting pretty warm by the time I was getting in the perlply. Hope it turns out!
I know the feeling when the laminating time is running out😄
Exactly!
Not the best layup I’ve done, but should work well! Had a hard time with the peelply and resorted to a metal spatula to pry it up in parts… That is where the scratches come in. But should disappear with a clear coat.
Cut a hatch out of 1/2 inch plywood.
Waiting for the gemlux friction hinge to be delivered tomorrow.
I had previously used the silicon pour around it for keeping out the water, but people seem to have good luck with EPDM weather stripping as well? Might try that?
Success! Didn’t have time to test before our road trip. But got a battery of riding in South Dakota.
Did forget the maytech remote, but luckily had brought a flipsky one that hasn’t been used yet. No solder iron with but shortterm fix to twist and tape the receiver wires to the correct connector for the ESC.
Excellent reception. Used a fiberglass and no carbon on the lid and had no problems. Had an expo on the ppm for the maytech, but using only uart. So had to mess with setting on the remote to not have it go crazy fast at low throttle. I wish there was a voltage read
The epdm gasket worked better then my silicon poured seal. Had to pry it loose to get it to release and not a drop of water.
Shared my motor mount here if anyone was interested:
https://www.printables.com/model/899322-efoil-slingshot-motor-mount-for-65161-motor
How many CF layers did you use when laminating the hatch?
I think a 4oz layer of fiberglass on each size. I went with fiberglass because the a rf for the receiver can penetrate way way better then CF.
What did you use for your battery box? I’m having a hard time finding one in the size I need.
3d printed it coated in epoxy and one layer of fiberglass. Then plexiglass top glued on with VHB tape.
I think I had a little water ingress last year… probably water that got into the mast and slowly dripped into the esc box while upside down.
So killed previous esc. And decided to waterproof in silicone a raidan 7.
Hi @brycej,
First of all, congratulations on the amazing work! I’m starting my project and am running into some issues modelling the board. Would it be possible for you to share the 3D file for the board?
