Swabian Efoil build
Thank you.
Yes, the the blades design is super important!
That is also a very hydrodynamic design, just without folding prop.
Jeah, there would be so much nice solutions. But my main goal is to keep it as simple and reusable as possible. With my current setup i just need to exchange the Mast and have a full Kitefoil/Wakefoil/Surffoil equipment. I already have too much equipment and it tends to get more :sweat_smile:.
Also, in a foildrive the pod is meant to be out of the water once it’s finished its job, so having an inneficient profile is not important as long as your power is enough to start flying…
Yes, but you can save a lot of more expensive Battery, Inverter, Heat, … if you have a more efficient prop which is more a question of clever design.
is this available to purchase? drkotary@gmail.com
Hey Micheal, I would like to print your prop for my lift foil but I need to modify the file to fit the lift motor. Would you share the CAD files? I used the STL to copy the hub, but the blade is a STL and I can’t complete my assembly to check tolerances and fit. If not no worries but figured I would ask! Cheers, Theo
Hi Theo, what file format would you need?
I would not want to upload my Solidworks project data.
But if a STEP helps i could send you one.
by the way, can you set a delayed speedup in a lift efoil?
Because if you plan to print the Blades in PETG with epoxy layer.
You destroy them yery fast if you ramp up to fast.
best regards Michael
Yes STEP would be great, thank you!
You can’t set the speedup rate on the Lift but I’m planning to print PETG and laminate with carbon fiber. Hopefully it will survive, we will see!
Hey Armin, has this contra-rotating propeller prototype ever been tested ?
It is in use already: Candela C-8 first flight: Testing the most premium flying electric boat in the world | Electrek
Its good that they provide the efficiency numbers.
Lets compare it against values reported here for efoils:
Candela c8: 650 wh/km @1700 kg
Efoil : 50 wh/km @ 100 kg
So, per kg:
Candela: 0.38 wh/(kg.km)
Efoil: 0.5 wh/(kg.km)
I expected a larger difference. Especially since larger vessels should be more efficient
I wanted to now what it costs to print the two blades only with “Strength AND/OR impact resistant” properties on a professional site with high-end materials.
https://craftcloud3d.com/ which also offers a nice viewer btw.
PEEK is a lightweight, industrial-grade thermoplastic polymer with high-temperature and pressure resistance.
Carbon-reinforced PEEK is stronger and stiffer than normal PEEK.
PEEK and Carbon fibre PEEK are only available in ASIA (Mantafoil propeller secret material ?)
The interesting part when printing Aluminium, 316L Steel or 17-4 PH Stainless Steel:
  • printing costs in Asia are 2 to 4 times cheaper than printing in Europe. what we could imagine. However…
  • shipping costs Asia to Europe are twice as less than printing in Europe and delivering in Europe … just unbelievable !
Prices are in EU/USD. The total cost below is for two blades only, no hub. Ordering the hub in addition would be without extra shipping cost.
2 blades only Print. cost Shipping Total cost Ships from
To EU
ABS 6,59 8,33 14,92
HIPS 6,97 11,9 18,87
ASA 7,66 11,9 19,56
PETG 7,66 11,9 19,56 EU
polycarbonate 12,69 8,33 21,02
Carbon fibre ABS 12,82 8,33 21,15 EU
Carbon fibre PETG 12,82 8,33 21,15 EU
FDM
Polypropylene
7,15 22,48 29,63
FDM Nylon 7,56 22,48 30,04
Carbon Fiber
FDM Nylon
8,34 22,48 30,82
MJF Nylon
PA12
13,3 24,48 37,78
Glass-Filled Nylon 13,48 24,48 37,96
Markforged® Onyx 19,67 41,65 61,32
Carbon Fiber
Polycarbonate
29,14 33,81 62,95 ASIA
Aluminium 44,36 24,48 68,84 ASIA
316L Steel 73,04 24,48 97,52 ASIA
17-4 PH
Stainless Steel
111,88 24,48 136,36 ASIA
Aluminium 166,85 42,09 208,94 EUR
316L Steel 220,77 42,09 262,86 EUR
17-4 PH
Stainless Steel
PEEK 68,39 24,48 92,87 ASIA
Carbon Fiber PEEK 68,39 24,48 92,87 ASIA
WIKI: PEEK can be processed by conventional methods such as injection molding, extrusion, compression molding etc. Thanks to these properties, PEEK and its composites are widely used in aerospace, automotive, structural, high temperature electrical and biomedical applications .
Last question: direct or via a hub ?
For a 316L print, direct via Sculpteo is -14%, in a EU to EU case.
The Asian manufacturing price remains unbeatable.
To EU
Site
316L Steel 73,04 24,48 97,52 ASIA Craftcloud
316L Steel 220,77 42,09 262,86 EUR Craftcloud
316L Steel 213 11,66 226,99 EUR Sculpteo -14 %
@leachim hi Michael, I really appreciate the time and effort you’ve put into your folding propeller. I am looking into the possibility of producing a community designed and built metal prop for less than 200€ and think your design would be a great candidate. Would you mind us casting and testing your design?
You can check out the link below.
Best mani
Hi, would you share your motor mount?
Hi Flo,
I can do, but I am currently very busy with new projects so it’s probably faster if you just design your own one. Mine is also very improvised. There are much better ones out there.
best regards Michi
Iam also interested in a stp file for the hub. i would like to adapt it for the bolt circle diameter for my engine, but with the stl almost impossible.
This is amazing. I’d love to have a filetype that would allow me to change the hole spacing to fit the holes on my Flipsky motors. Any chance you’d be willing to share?
Link to Files: Efoil 6384/63100 120kv-140kv folding prop by ThermikDreher - Thingiverse
