Cold but funnyđ
Hello Vincent, superbe vidĂ©o! Câest un shape perso?
Bravo ! c est fluide !
Shape? Di you mean the board?
Yes, the board. Is it DIY ?
All these details should be in the Vincentâs build thread I think⊠![]()
Which glue did you use to assemble the different pieces ? Where the pieces hot-wire cut ?
Which fabric layout did you use (ex bottom glass 200g + carbon bi axial 200g) etcâŠ
Did you take pictures or films during the manufacturing process and edit them in a video as did @Mat in his board building video ?
etcâŠ
This is my 3. ride with 80100. I need a lot of praktice.
Getting better
Interesting prop. Model air screw
Always a pleasure to watch , old video , maybe this board will be production one day ? , yes probably airplane prop , keep wanting to try a apc pro on my built , we donât need that much of blade area âŠ
Ok something a bit different / drone footage.
My large sup / FR motor / 7" FR prop / 6s 44Ah pack / Axis 82 wing foil / small 1- feet GLASS surf session.
One of the most magical days i have ever had on the water⊠just EPIC to fly on clear water like this and see everything your flying over. Was able to foil in and around other surfers without taking any of their usable waves or getting on the surf line which is important to keep the peace.
endless rides !
Enjoy
Now the weather is warming up in Australia itâs possible to fall in continuously without getting cold! Heres a vid of doing some jumps and carving in the river.
Reacher 120kv in action
How do you embed Vimeo video? I used the embed code but it doesnât display the player
Which set up is that? Geared drive?
Yes itâs a geared drive. SSS56104 and PLE040 gearbox
hello i love your lower pumping before jump on the noze foil awesomeđ
it s a new board and a new propulsion unit? you direct drive beforeâŠthe full alu unit look greatâŠ
Please talk more about it to the community
can you share or explain yours build?..what coupling did you use?
it s the way i have to folow!
and also i am convinced the gear box is the thing for electrique efficience direct drive is good to eliminate the maintenance and global cost .
Thankyou!!
Itâs a board I built, and the propulsion unit is built from CNCâd aluminium frame/mount/duct etc.
I agree, the added cost and complexity of a geared drive results in good efficiency and performance.
I will make a build thread soon with a video as wellâŠ
