Looks good! What you mean with “home” ?
only PWRFoil battery , in our website or at the factory in Perpignan (France)
Fliteboard patented their ESC on top of the mast 2 years ago. There definitely were not any other boards with similar setup then. Your first video only appeared 8 months ago. Better hope their patent is only for Aus
we never use Flite ESC , we use ESC with water cooling and we make the choice to don’t use salt water but closed system, so you don’t need to clear the water cooling.
I think Flite make a patented for their own ESC system , you can’t patented an other thing !
and we have old picture with this system !
we did our e-foil without looking much at the others
i have not problem with that.
E-foil : PWRFoil Switch model for rental , easy to change the board, inflatable board suitable.
So…you need to be careful with claims like this, they always come back to bite…
First pic clearly shows Mandarin in the factory and the rotor is identical to the Reacher/Maytech/Flipsky one.
Second pic posted in September clearly shows the same motor as Reacher, just with your branding.
Did you design this motor for Reacher?
Nice product and it is nice to have implemented the fresh water closed loop cooling idea to cool the ESC down.
The thing I will remember from this tortuous motor discussion is:
a Flipsky/Maytech/Reacher 120kv motor with a correct ESC works for an efoil with a 105kg human load (rider + son = 210 pounds).
In the video you have a version that rides under a board. Like a mini e-foil. Could you also ride the mini e-foil without a additional board on top? Also when your riding on the big board and you rapidly set back down on the water is there a significant feeling of drag from the mini e-foil under the board? How does the big board attach to the mini e-foil?
Pardon pour cette réponse tardive , mais je ne regarde pas souvent EFOILB. ;(
Oui bien sur il y a une protection d’hélice mais avec le coupe circuit , ce n’est pas indispensable , on gagne en vitesse et autonomie sans la protection!
les pré commande sont ouvertes , nous avons commencé a livrer … il y a 4a 6 semaines de délai en ce moment .
Pour le moment rien sur les sables.
https://pwrfoil.com/gb/home/626-propeller-pwrfoil-protection.html
Hey @chris, could you give us more details about the prop material ? Could be useful to complete the above link with such information
And the pitch too please!
Hi ,
sorry we are busy , this is ABS !
Do you guys have stock and are you selling boards and accessories currently?
Would you be prepared to sell the ESC case and Battery case separately?
yes , we have stock and some second hand efoil, sorry we are selling only complete efoil !
Why do you list parts like props, prop guards, boards and other accessories on the website then?
you can order the parts on the website, on your demand you spoke about esc , and batteries cases , there are not on the website !
Ah I see.
What’s the pitch on your prop?
What’s the depth of the cutout in bottom of your boards?
Hi Jezza, those accessories on the website are for customers in case of damages to be able to order replacement parts directly.
