@jeffM great thread here. I have a few questions for you (or others) as I embark on my first build.
exactly what foil did you use from gong? looks like XL but Im confused on their webpage options and the differences between S?UP/Kite/Surf?
-has anyone created fusion SLT files for the gong mast with pacificmeister’s SSS motor?
Flipsky 120kv, Gong XL Curve (1st post )
If I analyse correctly, the 20+% amp gain comes from a more triangular prop blade shape:
@jeffM, I find really interesting that your kill switch did not show any kind of damage on your V1 and V3 ESCs.
To know what to expect from a Gong XL Curve, what are now your take-off and max speed (even if speed is not your goal) ? Did you find/borrow a L or M Gong Curve to test/feel differences ?
Compared to the direct drive simplicity of the V3, what differences do you notice when you ride the geared V1 efoil again ? Would you build a geared efoil again or not worth the extra hassle ?
with the curve I don’t no exactly the speed for the take off (I will look at my GPS for the next ride) I think 13/14 km/h and Vmax 25km/h after there is a whistling certainly due to stab, and I don’t like the noise when I ride.
Never test L or M gong curve but I ride with a ketos foil with cruiser / wave XL and fr2
and the XXL curve start really earlier. But I tried it on a kitefoil, and it’s not very fun “pleasant”
it’s too big.
V1 more power but more noise, and more complicated for construction.
if i build a new one it will be with an engine like the flypsky
=> the gain 23A to 18A comes : new prop diam 132mm old 125mm
and i sanding the trailing edge (more sharp). I don’t think the shape improved
efficiency. Because I tried to do the same but you’re right it’s not realy the same
it’s more triangular but it’s exactly the same blade.
On the first propeller I had done a “dirty job” , I had a slightly different blade
look on the picture of the lower blade
@jeffM did you ever have to widen the hole in the back mast clamp? I have 3 8awg wires that I am trying to fit through this back mast clamp from the flipsky motor and it seems to be too tight of a fit.
No I didn’t need to widen the hole
it’s tight but it works with 3 8awg cables
I got the stl from the forum
if i remember correctly it was robert’s creation @nice2cu
he can answer if he reads this post
I am using the flipsky 65161/gong mast mount. My motor has these connectors on the end that are the issue, were these connectors on your flipsky motors?
