I have to disconnect the plug with +/gnd/signal because they are connected together on the same plug and this one go on the usb chip.
Thanks, but I don’t quite understand
I’m coming back to you with a problem on my Flycolor xcross HV3 120A ESC, which beeps as soon as I pull the trigger but without starting the motor, just after 3 sessions that worked fine.
I tested everything (other motor, other remote control, other receiver, everything works fine on my other boxes), I reinitialized the ESC via the blheli PC application, I checked the continuity of the 3 phases, I also checked the ESC calibration hypothesis, I performed the recalibration operation with the beeps, but nothing helped. I also check the 3 phase cables are OK. No problem connecting to the ESC via the usb dongle. What analysis and solution can you suggest?
Maybe this helps:
'Maytech motor beeps - doesn't work
Bec problem
What voltage you use for the receiver/esc?
It works with 5 volts
I tried with two BEC, and I also tried the BEC on the same flycolor xcross, the BEC works well, the receiver blue light is on (meaning receiver has current and remote is paired). I really hoped it was a BEC issue, but it’s not that. (I use 5V BEC).
It really seems that the ESC reboots each time I pull the trigger, (I see a vey litlle movement of the motor when I pull the trigger, and directly the 3 beeps of the arming sequence)
Have you reverted all settings in the blheli32suite to factory default?
If e.g autotelemetry is on and has issues when pulling the trigger this could reboot the mcu in the ESC. Just an example tho…
yes I reverted all settings to factory default, I also flashed to the latest firmware
Thanks for the idea, I will check again that telemetry is off
Maybe a mosfet is malfunctioning, can you remove the cover and check or is it potted?
Can I ask what thermal protection setting people have used on the 160a x cross esc? Thanks.
I found that at very low torque, and low trigger pull with the maytech remote, the motor is not spinning properly. Then when I seriously pull the trigger, It works nicely. Do you guys have the same behavior?
There is a deal now on Ali for X-Cross 160A at $62
https://a.aliexpress.com/_opBA3vO
Might be a scam, i ordered the cheapest on ali around christmas, no package was sent within the guaranteed time so i cancelled the order.
I just ordered one 7 days ago at this price, and just received it this morning, seems real
I must congratulate👍
Is the current protection setting measuring current at the battery, or at the phase wires?
I see that you’ve set current sense calibration to +100%, which would seem to double the reported current.
Anyone waterproofing the X Cross in any way? Thinking might just soak in Corrosion X before installing.
Will dip mine hv3 in thermal epoxy when I receive it. pre-potting with silicone to ensure heat sinks stay exposed. Then removing the silicone. If anyone tried something similar already I’m eager to hear.
