Hello to all,
First of all, thank you all for your answers and your examples which allowed me to realize my first efoil project in 2 months, without any knowledge in electronics.
For my first project, I tried to make it as simple as possible (almost no welding, no composite, no complex waterproofing, no trap door, no disconnection system in case of fall, …) and as cheap as possible, knowing that I already had the wing board and a foil gong.
I managed to do everything for about 1200 euros (excluding foil and board), and a 20h of work.
My components :
- Flipsky 75200 VESC
- Flipsky 65161 120KV 6000W motor
- Flipsky VX3 remote
- Waterproof case (I tried two aliexpress cases, supposed to be waterproof of course, but in fact not waterproof enough, I had to switch to a B&W outdoor cases to find the perfect waterproof case)
- PG9 connector + waterproof connector
- 8mm bullet connectors
- two lipos 6S 20A in serie (turnigy lipo), I have 40 minutes of flight time
- 200A fuse
- Flite propeller (adapted with a drill for 12mm flipsky 65161 shaft)
- Water cooling without pump, with a 8mm hole in front of the front clamp
- Gong V1 80 cm alu mast (too flexible, but with some epoxy in the plate, it’s ok, I’m sure GONG V2 mast is better)
- GONG curve LT front wing
- GONG kite 45cm FAST stab
- Gong Zuma 6.6 120L
- Crimp connectors to crimp the 6 black cables from the VESC + crimp connector
If anyone is interested, I can make a detailed BOM with the links.
I can also provide the STL for a V1 gong mat with the hole for the water cooling system.
With this setup, I can fly from 800W (for 67KG) at 19km/H, 1200W for 24 km /H, and 34 km/h max at 2200W, and I need 2600-2800W to take off.
My advice:
- Choose a branded waterproof box, and test without the electronics in it for waterproofing at all stages.
- Put the mast at the back of the tracks, because with the power of the motor, you really need to be at the front.
- learn in flat water, don’t underestimate the learning curve, I needed 3 session to fly for more than 100 meters, and maybe 5 session to fly unlimited time and carve as I want (despite being a kite foiler before)
To be improved:
- I will soon replace the curve LT by a veloce L for more efficiency, and especially a smaller board (I receive the gong first inflatable in 5.5 110L this week)
- The strap that goes around the board to hold the box, and that adds an important drag before taking off, if you have ideas to easily attach the box without strap around the board ?
- A duct in the back to test friends or my wife
Don’t hesitate if you see other ideas for improvements on the pictures of my setup:
Thanks again to everyone,
