Full and simple DIY efoil for 2500 € (detailed BOM)
here is the BOM of my efoil, which was designed to be simple to make and cheap, but sill working very well (very efficient, 24 km/H at 1200W) :
TOTAL complete EFOIL 2537
Board gong hipe first 5.5 300 https://www.gong-galaxy.com/produit/gong-wing-foil-board-inflatable-hipe-first/?attribute_pa_taille=55-fr
Foil gong curvle LT 579 https://www.gong-galaxy.com/produit/gong-wing-foil-allvator-v2-curve-alu-carbon-2/?gclid=Cj0KCQiAyracBhDoARIsACGFcS4FB1MSWyemibp5tiZJewDA8x7rvSxoygZsI2zaItHivv8v3FuFaaAaAik7EALw_wcB
Flispky kit 850 Group W7 Water Sports Kit (Includes High Current FSESC75300 /75200 and – FLIPSKY
Battery lipo 324 https://hobbyking.com/fr_fr/turnigy-high-capacity-16000mah-6s-12c-multi-rotor-lipo-pack-w-xt90.html
Charger 300 https://www.flashrc.com/ultra_power/30058-chargeur_up600_2x300w_12v_220v_ultra_power.html
waterproof case 95 https://www.digit-photo.com/B-W-Outdoor-Case-Type-4000-Noire-rOUT4000BSI.html
waterproof connector 15 Amazon.fr
Fuse 12 https://fr.aliexpress.com/item/4000493240607.html?gatewayAdapt=glo2fra&spm=a2g0s.8937460.0.0.3b3b2e0eIqGVEM
Flite propeller 42 https://www.custommotorsfrance.com/product/propeller-complete/
Shrimp tool 20 https://www.manomano.fr/p/pince-a-sertir-outil-de-sertissage-6-50-mm-cosse-de-cable-avec-poignees-antiderapantes-sertisseuse-9507871?model_id=9507871
PG7 https://fr.aliexpress.com/item/1005003216862912.html?ug_edm_item_id=1005003216862912&edm_click_module=item_detail&tracelog=rowan&rowan_id1=aeug_edm_19475_1_fr_FR_2022-01-18&rowan_msg_id=0179biz_add_wishlist%3A0%3A0_571083067%24dafb4d0c6fb845dba3c7a6be2204c416&ck=in_edm_other&gatewayAdapt=glo2fra
silicon tube connector https://fr.aliexpress.com/item/1005001610709560.html?spm=a2g0o.order_list.order_list_main.128.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
Connector for shrimped connection https://fr.aliexpress.com/item/1005003305443197.html?spm=a2g0o.order_list.order_list_main.248.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
Additional cable between case and motor https://fr.aliexpress.com/item/1005002882452517.html?spm=a2g0o.order_list.order_list_main.173.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
Serie connector https://fr.aliexpress.com/item/4000540401341.html?spm=a2g0o.order_list.order_list_main.263.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
Shrimp https://fr.aliexpress.com/item/1005002287282003.html?spm=a2g0o.order_list.order_list_main.259.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
Silicon cable water watercooling https://fr.aliexpress.com/item/1005003226573824.html?spm=a2g0o.order_list.order_list_main.294.4aed5e5bs5nhB1&gatewayAdapt=glo2fra
8mm bullet conectors
For more autonomy, 20A LIPO batteries
For more performance, change to Veloce L or MT.
I also bought a folding propeller (EML store) for 150 €, to be tried in waves soon.
Do not hesitate if you have any questions,
(detailed pictures of the build in this post : First easy and low cost build in France La Grande Motte )
