I am looking for any suggestions or feedback in implementing the watercooling feature of this VESC.
The aluminum block has two 8mm tunnels straight through it that have push in fittings that hold the plastic tube that Flipsky ships with it. The tube is very thin walled IMO and would easily kink so I will replace that component. Their design has the inflow into one of the passages returned and then travelling back through the the VESC to output on the same end it started. This is another design issue that seems flawed IMO as this would have water that has already absorbed some heat returning back through. It makes more sense to me to have the ambient temp water passing independently straight through the VESC so two inputs and two outputs. Those connections could possibly be implemented through two Y shaped fittings that will minimize the number of glands required.
I intend to use ram input only (no pump).
See photos for reference.
