For reference, here are your posts and a graph that I could find only in my knowledge base. According to this, in the most demanding conditions, 3300W are needed, which the 6374 motor can apparently provide.
Previously you used Apex 6384 170kv.
The question is whether that Flipsky 6374 can meet all the assist needs.
Update - calculation of required power:
According to the graph - current 80A, voltage 36v => power 2900w
For 12s , 12x3.6=43.2, 2900/43.2=67A.
2900w is less than max 3600w for 6374 motor and 67A is less than max 75A
Great!
Please report the difference. Is the 6384 worth the extra cost and weight?
Currently, on AliExpress, the 6384 costs 50% more than the 6374 and weighs more.
How do you treat that motor. Spray with corrosionX?
Yes it’s a monobloc gong V1.
I use it because it’s the lightest gong mast
it’s quite difficult to pass the cables through it because there is less space than the V2 monobloc.
I modified the rear to be able to install the new stab and also to be lighter
How did you manage to achieve 2 hours of runtime with a total weight of just 15 kg? My 2-hour battery alone weighs 11 kg, not including everything else. How many watt-hours is your battery? Also, when you mention 2 hours, is that the total time on the water or the actual time you’re powering the efoil motor?
will the ceramic bearings last? i tested a normal 6384 engine and one bearing broke after just one lap. (because it is axially loaded) I only had 6S operation with a folding propeller.
I 3d printed that prop and can run it on 10s and 12s. Currently I’m testing out a range off new props to see what they offer and which are best suited for different flavours of riding.
Hello, I would also be interested in the propeller file.
Commercial solutions are not suitable for me because I need one to rotate in the opposite direction to the other for the tow that I have been preparing for some time
I saw that most are using 10-14s and I assumed that it would be no problem with 16s then. Is there any downside to using 16s? I have a friend who builds battery packs and he would build me a 16s10p battery for the foil.
